1953 tru 56 front straight axle
According to the parts book/s the F100 and the F250 use the same King Pin sets on the axle/spindle connection. That would lead me to believe the spindles could be swapped so that you could do to your F250 axle that you want to do. Maybe someone with hands on experience with this could weigh in.
The following users liked this post:
My understanding is that the backing plates from the F250 are the same diameter as the Buick finned aluminum drums. I am sure that there are some other details but this is the extent of my knowledge. I bought parts from a guy who bought a whole F250 just to get the backing plates and was parting out the rest of the truck since he had what he wanted in the brakes.
The front axle and spindles are the same for 53-56 F100 and F250. You can take the 8 lug hubs off and replace with 5 lug, using the half ton brakes with it. Alternatively, any disc brake kit for a 53-56 F100 will fit just the same on the F250 spindles, if you want to do that upgrade.
The following 2 users liked this post by 52 Merc:
Thank you for the information. I was hoping they might be the same, but I did not have a F-100 truck here for comparison. I plan on using a early 70's F-100 9" rear axle assembly in order to get rid of all the 8-lug stuff and use the more common 5 lug wheels. I really do not need the heavy F-250 axles for my use.
TheWedge1
03-23-2012 02:03 PM
robertr
10-22-2002 12:40 AM
