Codes and engine light
Old Jan 12, 2022 | 11:04 AM
athon0520's Avatar
athon0520
Hey everyone,
so I have a 2011 6.7, bought it with a previous tune that I have no idea about. I don’t have the screen to check the data. But I’ve got a check engine light on, I’ve hooked up a code reader to it and received a P02DA which is the cylinder 8 injector offset learning at a minimum. I’m wondering if it’s because of the tune? Everything drives and runs just fine! So just some help, is it something I need to worry about? Thanks.
-Athon
Old Jan 13, 2022 | 05:29 AM
senix's Avatar
senix
This is a problem for all that buy a truck with tunes that are unknown and no tuner with your factory tune on it.
I am afraid you are pretty much on your own wtth this. I would suggest you get forecan and learn how to use it, then consider using that to test the injector, if you decide to replace it then you will need that to program the new injector into the pcm.
First try a little fuel injection cleaner for diesels.
Shawn1021
Jul 11, 2021 01:14 PM
FSFT
6.7L Power Stroke Diesel
Nov 20, 2018 10:09 AM
BearFootCustom
Oct 20, 2010 10:44 AM
ford1183
28
May 25, 2008 07:57 PM
Forddieselweasel
Nov 9, 2004 05:06 PM
