Codes stored?
Old Nov 9, 2004 | 10:30 AM
Forddieselweasel's Avatar
Forddieselweasel
Codes stored?
Hey found a obd scanner i can rent for my 92 150. The problem is my check engine light only comes on for like 1 min or 2. Does the light have to be on to check it, or is the code stored? Thanks
Old Nov 9, 2004 | 10:33 AM
EPNCSU2006's Avatar
EPNCSU2006
There should be a code stored in the memory, even if the light isn't currently on.
Old Nov 9, 2004 | 11:32 AM
qman's Avatar
qman
I also have a 92 f150 and lastnight as I pulled away from the curb my check engine light came on. What type of scanner do I need for this truck? Is it OBD I or II?
Old Nov 9, 2004 | 02:43 PM
EPNCSU2006's Avatar
EPNCSU2006
It is OBD, but you actually don't need a scanner at all. All you need is a jumper wire (paper clip) and the computer will blink out the codes on the check engine light. The instructions can be found here: http://fordfuelinjection.com/index.php?p=13
Old Nov 9, 2004 | 05:06 PM
qman's Avatar
qman
Great website. thanks for the info.
