Check engine light
Old Feb 13, 2019 | 09:42 AM
Shawn1021's Avatar
Shawn1021
Check engine light
I have a 96 F250 5.8L that the check engine light comes on at highway speeds. Can't pull any codes because the light goes out once the key is turned off.
Old Feb 13, 2019 | 12:29 PM
xlt4wd90's Avatar
xlt4wd90
You should be able to at least do a KOEO test. That should display stored codes.
Old Feb 15, 2019 | 09:09 PM
baddad457's Avatar
baddad457
Any good code reader should show the stored codes after the engine is shut down.
Old Feb 18, 2019 | 07:13 AM
Shawn1021's Avatar
Shawn1021
ODB1 does not hold any codes. I've had it checked by several different scan tools. All give a 111 code. Which is everything is working fine
Old Feb 18, 2019 | 02:23 PM
rla2005's Avatar
rla2005
By design the OBD-I system is capable and will store codes.
Was the engine running when you tried to pull the codes? If so, that's not when the stored codes are displayed.
Old Feb 18, 2019 | 02:27 PM
Shawn1021's Avatar
Shawn1021
No it wasn't. Will test again with engine running
Old Feb 18, 2019 | 03:47 PM
rla2005's Avatar
rla2005
Negative....
Now that we know when you got your Code 111 (based on your response "All give a 111 code", which assumes you got that for the KOEO tests and the Stored Code display) you need to pull out the computer then inspect for signs of the very common leaking capacitor(s) and/or burned components/traces.
Since you did get a Check Engine Light previously there should be a stored code, unless the Keep Alive Memory (KAM) power is missing or the computer has an issue. Usually with no power for the KAM you will get a Code 512.
Old Jul 11, 2021 | 01:14 PM
Fireferg73's Avatar
Fireferg73
Deleted……..
FSFT
6.7L Power Stroke Diesel
Nov 20, 2018 10:09 AM
BearFootCustom
Oct 20, 2010 10:44 AM
97F250LD4X
1997 - 2003 F150
Mar 3, 2006 11:38 PM
npalao
Jul 21, 2005 11:03 AM
j94tbird
Jan 8, 2005 09:38 AM
