Boost Relief Valve
Old Jan 11, 2022 | 10:02 AM
MiamiPSD's Avatar
MiamiPSD
Boost Relief Valve
Can anyone identify this boost relief valve which I purchased many years ago (can't recall the vendor) and the reason it has two relief valves VS the ones I have seen out there with only one?
Old Jan 11, 2022 | 12:39 PM
GregA's Avatar
GregA
That's interesting...kinda curious why you installed that? I can't see why it's needed at all.
Old Jan 11, 2022 | 12:49 PM
MiamiPSD's Avatar
MiamiPSD
I think thats what was available at the time of purchase. Don't know why two relief valves.
Old Jan 11, 2022 | 01:23 PM
GregA's Avatar
GregA
Don't know why one relief valve (am I missing something?)
I'd remove it entirely.
Old Jan 11, 2022 | 01:28 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Why did you install that?
Old Jan 11, 2022 | 01:46 PM
woodnthings's Avatar
woodnthings
The relief valves were not consistent, so they installed two to ensure the MAP sensor wouldn't see high boost and defuel. We are lucky to have components like the Riffraff OCR that is very accurate and eliminates defueling and codes.
Old Jan 11, 2022 | 04:28 PM
GregA's Avatar
GregA
So that compressor safety valve was installed to keep the MAP from seeing high boost? We used to do the same thing with fish tank valve on the Dodge turbo cars...allowed us to cheat in Showroom Stock racing.
Old Jan 12, 2022 | 02:01 AM
woodnthings
Yes, it bled off boost to the MAP sensor to make the PCM think it was only seeing XX psi of boost. They were not always reliable though, cheap regulators were also used as well.
Old Jan 12, 2022 | 06:42 AM
MiamiPSD's Avatar
MiamiPSD
Thank you all. I will contact Riffraff to order one and swap this one out.
jdamato1
Feb 19, 2010 10:17 AM
f350rebel
Jul 1, 2007 08:49 PM
fordf350crazy
21
Mar 24, 2005 04:12 PM
AKESPY
May 18, 2004 09:27 AM
stroken38s
Mar 4, 2004 07:15 PM
