Tips
Old Jan 10, 2022 | 07:39 PM
Ilijad7579's Avatar
Ilijad7579
Tips
I have a 95 f150 2wd 5.0 xl and I just swapped the rear end yesterday. I went from a 3:08 gear ratio to a 3:23 gear ratio. Now it seems to be messing with the transmission, and the trans never had issues before. Also the check engine light turns on when accelerating and turns off when I reach my desired speed. I've never had this issue before, even when I regeared my bronco to 4.11 gears it never messed with the trans. Any advice is appreciated.
thanks,
Ilija
Old Jan 10, 2022 | 07:55 PM
wwhite's Avatar
wwhite
Here is a tip: "use a descriptive subject line in your post, rather than ""TIPS"".
I actually read "****", as I don't have glasses, and you want to talk rear ends.
Ok, what transmission?
Pull codes off computer.
Did your rear end have the Vehicle Speed Sensor(VSS) in it?
Did you swap them?
Ilijad7579
General Automotive Discussion
Jan 10, 2022 07:20 PM
wgb
1966 - 1977 Early Broncos
Nov 1, 2019 12:58 AM
AZTod
Jun 24, 2019 08:19 PM
Johno.h
Apr 16, 2016 09:53 AM
RB35
Aug 15, 2006 12:18 PM
