Blowing Fuse
Old Jan 9, 2022 | 10:59 AM
Newmonster's Avatar
Newmonster
Blowing Fuse
Hello all, I recently purchased a 1996 F350 7.3 powerstroke CCLB. Its got a few issues, the one I'm having a hard time with right now is the number 17 fuse keeps blowing. It blows the second I step on the accelerator, it can be in park and will still blow as soon as I step on it. I can shift through the gears and it's fine. Anyone have any ideas on where to start with this? I have already been under the dash and could not see any obvious signs of shorting. Thank you in advance everyone.
Old Jan 9, 2022 | 02:38 PM
Hit Man X's Avatar
Hit Man X
Well, underhood or in cab?
Old Jan 9, 2022 | 02:50 PM
Newmonster's Avatar
Newmonster
Number 17 fuse in the cab fuse box.
Old Jan 9, 2022 | 03:00 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I donned my special carnac headware to recall what is on that circuit:
Trans control indicator lamp and switch
Brake level switch
Warning chime
Diesel warning lamps
Fuel water switch
Low vacuum switch
Instrument cluster
Electric shift control switch lamps
Disconnect the easy crap and go from there. No clue the last one, maybe for electric shift transfer case. You could also disconnect the TPS and leave the idle switch, try again. If pops, reverse that, try again.
What happens once said fuse pops?
Old Jan 9, 2022 | 03:06 PM
Newmonster's Avatar
Newmonster
After the fuse blows I lose all my gauges with the exception of the speedo.
Old Jan 9, 2022 | 03:10 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Odd, but like I said...disconnect the crap on that circuit then go from there.
Old Jan 10, 2022 | 07:33 AM
ajjw0828's Avatar
ajjw0828
Another guy had a similar issue. Never heard back if he got it fixed. Good Luck!
https://www.ford-trucks.com/forums/1...s-blowing.html
raceman4
Feb 13, 2021 07:12 AM
Ryan Byrd
Oct 24, 2018 08:19 PM
drivefaster35
Mar 3, 2017 11:13 AM
eigood56
Jan 16, 2015 09:01 PM
fishman002
Jan 2, 2008 09:22 AM
