Electrical Short
Old Feb 12, 2021 | 04:33 PM
raceman4's Avatar
raceman4
Electrical Short
1994 F350 IDI Automatic Can be shifted manually if not shifted manually it will blow a fuse. Any help would be appreciated
Old Feb 12, 2021 | 06:10 PM
torq'ta 5 8's Avatar
torq'ta 5 8
what fuse? which automatic? if E40D maybe
E40D: The Importance Of A Clean Trans Harness. - Ford Truck Enthusiasts Forums
Old Feb 12, 2021 | 06:23 PM
raceman4's Avatar
raceman4
e 40d the fuse that lets the transmission shift in to low gear
Old Feb 12, 2021 | 06:25 PM
raceman4's Avatar
raceman4
3 transmissions did the same thing
Old Feb 12, 2021 | 06:53 PM
raceman4's Avatar
raceman4
it blows the pcm coil power relay fuse
Old Feb 12, 2021 | 07:10 PM
raceman4's Avatar
raceman4
e40d it blows the pcm coil power relay fuse
Old Feb 13, 2021 | 07:12 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It’s an E 4 Oh D which is the abbreviation for Electronic 4 speed OverDrive. It is not an E Fourty D.
Sorry. Now back to your regularly scheduled program.
Since you apparently have had several transmissions in this truck.. is sounds like there is a problem in the harness. I’d suggest following the harness from the trans connectors back to the computer. Maybe it got damaged from a previous repair or rodents?
Ryan Byrd
Oct 24, 2018 08:19 PM
drivefaster35
Mar 3, 2017 11:13 AM
fishman002
Jan 2, 2008 09:22 AM
ncguy23
Electrical Systems/Wiring
Jul 27, 2007 03:33 PM
mmmPowerStroke
Jan 4, 2006 07:14 PM
