Coil pack
Old Jan 5, 2022 | 12:58 AM
wtroger's Avatar
wtroger
Coil pack
I had noticed a miss under load on my 2002 ranger 3.0 though it was fuel. Then a few days later I got a hard miss and a flashing check engine light. Got it home and code said 304. I pulled the plug and swapped it with another one I had didn’t change nothing swapped a wire no change finally got out the spark test and put it in the top off the coil pack for number 4 no spark. Put it in the top of of number no fire there. Replaced coil pack and wires and she runs like new. I think this might have been caused by a loose plug wire on number 4. Moral of this story is check your spark plugs wires ever so often to insure connection the connections are good.
Old Jan 5, 2022 | 09:57 AM
pawpaw's Avatar
pawpaw
Good troubleshooting, find, fix, feedback & to hear all now seems well.
If you stiill have the old coil pack, turn it over & check for case cracks underneath & carbon tracks to where it may have been arcing to ground unseen. Coil pack Case cracks underneath are a rather common failure mode it seems. Also ohm out the secondary winding between terminals 3 & 4, should be 13-15K ohms. Would be most unusual to be open circuit.
The primary winding will be 1 ohm or less, so would need a really good meter to actually measure its resistance, so it'll be really low but not open circuit, which would be most unusual
Jose A.
Aerostar
Apr 11, 2014 12:35 PM
seagull369
Jan 20, 2014 03:18 PM
boaterdude83
Sep 18, 2008 12:42 PM
mudder460
Jun 2, 2007 12:30 PM
barrett_ross2
3.0L V6
Dec 7, 2005 11:47 PM
