Dagenham 4 speed
Old Feb 5, 2022 | 05:58 AM
User 71024's Avatar
User 71024
Originally Posted by 85e150
A "Toploader" is the performance Ford transmission introduced in 1965 to replace the BORG WARNER T-10, a side loaded transmission. A toploader is NOT a T-10.
As for the RUG transmission, those are built on the toploader pattern. There are pictures here. Issues might be bolting it to your bell--the six vs. V8 patterns different. You might be able to drill it to fit. The input shaft length needs to be sorted out.
Toploader Imposters
There are other versions of the 4 speed OD, and the SROD uses a remote shifter vs. the external linkage of the RUG transmission. It may be able to be converted to a more remote shifter but keeping it on the column would be a challenge.
More ratio and application info.
https://www.5speeds.com/toploader.html
Sorry, had t-10 on the brain. Bolt pattern shouldn't be an issue and if the shaft is too long I can probably mill a spacer, I'll make that decision when I have something in my hand.
Old Mar 1, 2022 | 08:11 AM
User 71024's Avatar
User 71024
Just a bump;
SHOT IN THE DARK! Anyone have a 4 speed shifter for the Econolines
Old Mar 2, 2022 | 07:54 PM
85e150's Avatar
85e150
Econollne info sources:
https://vintage-vans.forumotion.com/...ral-discussion
Econoline dot Org
Old May 6, 2025 | 10:38 PM
Richard Davidson's Avatar
Richard Davidson
1st Gear
4 speed ?
What I would do is use the 3 speed linkage for the 4 speed, then use a pto cable for reverse, it will work as long as the shifter and it's components are in relatively good condition.
Old Sep 18, 2025 | 06:58 PM
Econosaurus's Avatar
Econosaurus
4wd Low
Originally Posted by User 71024
Just a bump;
You last posted on this in 2022, I am curious how this project has gone. I am gathering info on column shift with the potential for doing a 5 speed...
Karl
1951flatheaddave
21
Jul 9, 2020 03:30 PM
HotRod 66 F100
26
Nov 7, 2012 11:52 AM
STEVE1103
Oct 27, 2011 01:34 PM
littlewhitetruck
Sep 7, 2008 08:29 AM
scjfox
May 26, 2008 02:37 AM
