A little something!
Old Jan 6, 2022 | 07:04 AM
Listor's Avatar
Listor
Alternatively, run crazy high boost and EBP to keep the tube clear.
I try to not keep my foot in it all the time! LOL
Old Jan 6, 2022 | 09:14 AM
twayne85's Avatar
twayne85
Originally Posted by Jimmy's Pilot Service
Depending where you are in Texas you may be getting winter fuel. That alone has been known to drop milage.
Originally Posted by aawlberninf350
I imagine when the EBPV activates it could back up more particulates in the exhaust manifold than during normal flow. But that doesn't happen very often for most folks. Otherwise the EBP sensor and tube will still be subject to the normal contamination and need cleaning once in a long while. Monitoring the back pressure with Forscan or something would show if it's a problem.
As mentioned winter fuel hurts mpgs. A heavy bumper has an impact but 2 mpg is more than I'd expect.
Thank y'all. Doubt its winter fuel since I'm in central Texas. Never known any stations in our area to switch. I can monitor on forscan and see what it shows. Seemed to come on after getting the bumper though. Its 260 lbs. The last 2 tanks were a little better than the previous ones and I'm closer to my normal average but still down some.
Old Jan 6, 2022 | 09:26 AM
Listor's Avatar
Listor
Originally Posted by JOHN2001
Don't forget to clean the fitting on the manifold too. This is the only place mine was caked, the tube was clear.
this goes all the way through
Old Jan 7, 2022 | 02:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Thanks for spreading the word about this somewhat uncommon tool Don. I used a lawn mower throttle cable years ago and it did a decent job. Something like this is a nice to have item in the tool inventory.
Also, I am always looking for a reason to buy more tools...
Old Jan 7, 2022 | 06:36 PM
WNYPSDguy's Avatar
WNYPSDguy
I got mine on Ebay awhile ago, pretty sure I saw them on Amazon also. Surprised at how well it worked without pulling the tube off. That made it very worthwhile for me.
Old Jan 7, 2022 | 11:23 PM
Hyakkimaru's Avatar
Hyakkimaru
That's an interesting tool! Never seen that before! When I cleaned mine I used a bit of weed eater string. Playing with brake clean and just kept pushing on it until I got it through. Fed it through to the other end and put a drill on it and spun it for a while and occasionally shooting some brake clean through it and all kinds of sooty goodness came out! In a pinch you can come up with stuff!
Old Jan 8, 2022 | 07:58 AM
Listor's Avatar
Listor
they say necessity is the mother of invention!
Old Jan 8, 2022 | 09:54 AM
jstihl's Avatar
jstihl
Dial Spider Snake 24 " Clamshell
Amazon Amazon
here is a link to buy on Amazon, went to buy at Lowe's but needed a $45 minimum for free shipping.
Old Jan 8, 2022 | 07:38 PM
kd5zll's Avatar
kd5zll
Well alrighty then.... here, i was about to replace my map sensor, but looks like i need to clean this tube and fitting out, first. Man i love this place.
Old Jan 9, 2022 | 07:44 AM
Listor's Avatar
Listor
Originally Posted by jstihl
Dial Spider Snake 24 " Clamshell https://www.amazon.com/dp/B008RPS04S...TT82YTK611NDD2
Interesting how something so little can gain such traction, glad i could contribute a little something after all you guys do for everyone else!
Charlie Fox
Jan 8, 2026 01:36 PM
Squirrel13
Jul 8, 2023 07:10 AM
dantimdad
521
Aug 25, 2021 02:08 PM
Max Capacity
15
Apr 19, 2021 03:06 PM
A/Ox4
May 30, 2012 09:45 PM
