6.6 Engine Help
Old Jan 4, 2022 | 09:40 AM
Byrd.Dog's Avatar
Byrd.Dog
6.6 Engine Help
I posted in the 335 Engine forum, but thought I might get a few more views here, since quite a few of you guys have these in your trucks. Any help would be greatly appreciated!
https://www.ford-trucks.com/forums/1...n-clatter.html
Old Jan 4, 2022 | 10:18 AM
mark a.'s Avatar
mark a.
Have you taken it back to the shop that rebuilt it ? Seems like it should be their problem.
Old Jan 4, 2022 | 04:18 PM
Byrd.Dog's Avatar
Byrd.Dog
Unfortunately, it's been several years since the rebuild. In any case, I'm sure I'd have to pull the motor and I'd prefer not to do that.
Old Jan 4, 2022 | 06:13 PM
Yamhill Ranger's Avatar
Yamhill Ranger
+1 for lifter pre-load
I didn't see mentioned, but you replaced the lifters, AND pre-soaked them AND burped them prior to install?
When you pull the valve covers if nothing immediately signals the issue, then it's time to verify the preload.
This is a general orientation description, you can find many articles with more step by step.
Start with number 1 at TDC, and you should be able to spin both the intake and exhaust pushrod by hand (if there's a ton of pre-load, you might have to loosen the hold down bolt 1/4 turn). but there shouldn't be any free-play as you try by hand to push the rod end of the rocker up and down. then rotate the crank 90deg clockwise and go to the next cylinder in firing order, etc.
Unless you somehow have an adjustment capability in the (stock?) 335 rockers, you will probably need to order custom length pushrods and/or switch out your rockers to adjust the preload.
Old Jan 5, 2022 | 07:41 PM
Byrd.Dog's Avatar
Byrd.Dog
Machine shop rebuilt the motor, so i am assuming any procedures needing to be done on the lifters prior to assembly were completed. Hopefully will get the chance to pull valve covers this weekend to check pushrods, rockers, & springs.
VocaTexas
Aug 12, 2013 07:07 PM
Camper Special Gene
Jul 29, 2013 05:04 AM
Jdenninger
New York Chapter
Apr 6, 2007 10:35 PM
Brians1966
15
Dec 31, 2003 07:54 PM
