Water Pump leak
Old Jan 1, 2022 | 11:41 AM
OldFord87's Avatar
OldFord87
7th Gear
Water Pump leak
I purchased a 1987 F-150 Lariat XLT about two years ago, and had no issues until last May, when the water pump developed a leak. I replaced it no problem and 3 months later it started leaking again, from the same spot. I am on my third water pump when once again as of yesterday it started leaking again from the same spot. It appears to be leaking from weep port, at a significant rate that drains the radiator. Does anyone know what could be causing this repeated leak to develop?
Old Jan 1, 2022 | 12:07 PM
f31951truck's Avatar
f31951truck
Possibly a belt being too tight or and alignment issue with the serpentine belt causing the bearing to wear prematurely. Could also be bad pumps. Quality of aftermarket parts is hit or miss these days. Good luck.
Old Jan 1, 2022 | 01:37 PM
88n94's Avatar
88n94
Were all 3 pumps the same brand?
Old Jan 1, 2022 | 01:47 PM
sandymane's Avatar
sandymane
A Motorcraft water pump is about $80.00. Almost double the price of other brands on ROCKAUTO. I would buy the Motorcraft and here is what you should do according to them to prevent premature failure like you are experiencing.
Cooling System Maintenance | Tips & ToolsWithout regular maintenance, cooling system components will degrade and fail prematurely, which can lead to costly engine damage. Protect your engine with simple preventative maintenance:
  • Completely drain and flush the system using Cooling System Flush prior to installation. Flushing the system is critical to prevent system contamination and failure.
  • Consider replacing the Radiator Hoses (and Hose Clamps), Thermostat and Radiator Cap as part of routine preventative maintenance. System contamination can cause these parts to degrade and fail over time, which can lead to severe engine damage from overheating.
  • Refill radiator with fresh Coolant / Antifreeze according to the volume and formula specified in your Owner's Manual. Inspect levels and condition every year.
Old Jan 1, 2022 | 01:48 PM
OldFord87's Avatar
OldFord87
7th Gear
The first water pump was the original, but the two replacements were the same brand, a Carquest Premium waterpump from Advanced Auto.
Old Jan 1, 2022 | 04:16 PM
spurredon's Avatar
spurredon
The Motorcraft parts seem to have a better lifespan than the Chinese parts from other manufacturers. Two bad imported parts in a row is not super uncommon. My parts guy always says" save your receipt", and then chuckles as I walk out. Even the NAPA stores have been forced to buy lower priced parts to be able to compete for quite some time now.
Old Jan 1, 2022 | 08:34 PM
wwhite's Avatar
wwhite
Last water pump I bought about 4 years ago was a Motorcraft from Rockauto, Made in Mexico.
Old Jan 1, 2022 | 09:27 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Here napa's china junk, is still higher than giraffe &^%%#$@
Old Jan 1, 2022 | 11:40 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Flowcooler makes solid pumps, just popped one on an L98 C4 last year. I have their old style on my '88 or maybe the Edelbrock high flow from forever ago...I forget as has been so long.
Old Jan 2, 2022 | 07:42 AM
AuroraGirl's Avatar
AuroraGirl
Ive gotten lucky with a partsmaster from auto value. no idea who made it. but so far, lucky.
Old Jan 2, 2022 | 01:06 PM
2dwoods's Avatar
2dwoods
I just did a pump six months ago now I see a leak at timing chain cover so coming back apart and might as well tap a new front main seal in while its apart ,moral of the story consider doing timing cover gasket while its apart if its been a while mines a 95 and I've never done chain cover
Old Jan 2, 2022 | 04:58 PM
spurredon's Avatar
spurredon
At least you shouldn't be busting those %"#^&! long skinny bolts since you have changed it recently!
Old Jan 2, 2022 | 06:30 PM
2dwoods's Avatar
2dwoods
Yes sir been there done that
Old Jan 3, 2022 | 01:39 AM
AuroraGirl's Avatar
AuroraGirl
A long long long time ago i couldnt do this right becuase i was dumb as hell and had housings break like almond bark. then i didnt turn the pipe fitting enough out of fear of cracking it too. Then I used RTV to hold thermostat and the bead around it became more than it should. The water pump was actually my first WP and I actuallly succeeded well on first time surprinsgly no leaks
Old Jan 6, 2022 | 04:45 PM
OldFord87's Avatar
OldFord87
7th Gear
Thank you all for the responses and help. Replaced the water pump with a higher quality one this time so hopefully I don’t run into this issue again. All the help was much appreciated!
jte1998
Mar 23, 2021 07:38 AM
6fifty_f1fifty
Nov 22, 2010 02:07 AM
gofast51004
Mar 5, 2009 08:53 AM
Sirdrinksalot
Aug 6, 2008 12:19 AM
robinsonpowerstroke
15
Apr 2, 2008 09:04 AM
