Sponsored by: Real Truck
Sloppy steering
Old Jan 1, 2022 | 02:11 AM
Cool Ron's Avatar
Cool Ron
Sloppy steering
Good morning and happy New Years!
I recently replaced my front diff, diff and pinion bearings and seals, hubs, vacuum seals, locking hubs, knuckle ball joints, drag link, drag link adjusting sleeve, LH and RH inner and outer tie rods, steering damper, and center link on my 2015 F-350 4WD SRW truck. Everything was Motorcraft except for the knuckle ball joints which were Moog. I then had the truck professionally aligned. Prior to this my steering was tight. Now it is not. I am constantly making slight adjustments at highway speeds. What did I do or not do to get this sloppy steering? How do I fix it? Thank you!
Old Jan 1, 2022 | 07:33 AM
Calebt's Avatar
Calebt
8th Gear
that happened to me on my 2001 f250, what I did was tightened the ball joints wrong. there is a sequence to follow I had to loosen them up tightened them the proper way and it fixed the problem for me
lhwalker22
Dec 23, 2019 12:24 PM
Blue7.3
Australia Chapter
57
Aug 21, 2014 04:42 AM
Fordman96
May 22, 2012 11:27 PM
teg2_nv
Jun 13, 2006 06:21 AM
