Steering Issues
Old May 19, 2012 | 08:45 AM
Fordman96's Avatar
Fordman96
Steering Issues
My dad has a 2002 Limited X and my uncle had a '99? F350 dually. Both have this issue:
-Occasionally when driving down the road the truck will suddenly just try to veer off to one side or the other and then the steering gets really rough (The steering wheel moves back and forth rapidly. My dad has to pull off to the side of the road, completely stop and turn the wheel all the way to each side twice and it seems to correct it momentarily.
-The other issue is that when making a corner there will be a hard "thump" noise, and then the before mentioned issue occurs.
My dad has replaced all 4 ball joints, the 1 bad tie rod and has gone through a set of Warn Lockout Hubs (In less then 6 months. He had to drive around with the hubs locked in to prevent the truck from pulling due to warn out needle bearing. This somehow resulted in the passenger side Hub being internally destroyed and that wasn't even the side the bad ball joint was on.)
We're just curious to know if anyone else has come across this issue and/or knows a way to fix it.
Old May 19, 2012 | 09:57 AM
timf150's Avatar
timf150
What you are describing sounds very familiar to what some users experienced in this thread.
Quite a few pages but I believe ExV10 finally solved his issue with new u-joints.
https://www.ford-trucks.com/forums/8...and-forth.html
Tim M
Old May 19, 2012 | 03:22 PM
Fordman96's Avatar
Fordman96
I'm not entirely sure but I believe he has put in new u-joints and the problem still exists. I'll find out later
Old May 22, 2012 | 11:27 PM
Nof1's Avatar
Nof1
I had a problem almost like ur dads x...i changed the power steering pump cuz it was leaking then the ujoints that are between the front axle and front rims my problem went away ... Is the excursion 4x4 ?
viperbluelx
Jul 20, 2019 09:55 PM
651_F350_KR
May 22, 2018 12:33 PM
jayboss1
Aug 25, 2012 06:35 PM
crazer42
Jan 6, 2011 10:49 PM
