AC air flow problem
Old Dec 27, 2021 | 05:10 PM
hawkco66's Avatar
hawkco66
AC air flow problem
2000 Excursion, 7.3L Diesel. 4x4
AC started blow from the defrost yesterday. I've dealt with this before so today I started trouble-shooting.
Here's what I found:
Vacuum motor pulls 17psi.
Vacuum tank holds pressure--no leaks.
With vac gauge "T" into the system---holds 17psi steady. No leaks.
I had hoped I would find a bad actuator, but all three move correctly with corresponding movement of the dash controls.
I can get air to flow to defrost and to the floor, but never the panel.
I believe my problem is with the panel/defrost door on the driver's side under the dash. Because I can see the actuator moving the door arm back and forth under vacuum I am thinking the door itself has broken from the arm and is lodged in the defrost pathway.
Anyone else experience an actual broken door or have an idea about anything I'm missing?
thanks,
Greg
Old Dec 27, 2021 | 05:42 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Have you checked the 4x4 vacuum switch located on the passenger inner fender just behind the battery ( on gasser) That cracks and can cause the ac to default to the defroster. Are your hubs engaging in 4x4? Common problem.
Old Dec 27, 2021 | 06:15 PM
hawkco66's Avatar
hawkco66
yes, thank you. When I was checking the pump and the tank I unplugged the lines going to that solenoid and plugged the vacuum line running to it. I considered that the solenoid may have failed again. I replaced it about 2 years ago I think. Sadly, this isn't the problem. I have good vacuum, no leaks. much appreciated.
Old Dec 28, 2021 | 04:38 AM
01__Excursion's Avatar
01__Excursion
I was looking through my pics of when I replaced all the front A/C stuff, I don't see any pics that may help you verify if the door is broken. I remember having just enough room for me to fit my hand and a 1/4 ratchet and socket in there to remove the damper motor screws, that would allow you rotate the motor and door together, while rotating the 2 pieces you should reach a stop point in either direction if the door is ok.
Old Dec 28, 2021 | 11:00 AM
hawkco66's Avatar
hawkco66
I hadn't thought of that. That is a good idea. I will try that. thanks.
Old Dec 29, 2021 | 07:23 AM
hawkco66's Avatar
hawkco66
I removed the actuator yesterday evening. I reach through the maze of wires and grabbed the door's arm. The arm would move, but didn't move the full range. By moving it back and forth I was able to free it up to move the full range. I don't know what caused the problem, maybe a kid put something down the vents? Either way it moved freely back and forth. I started the engine and ran the AC. While under the dash I moved the arm back and forth. I could hear and feel it close solidly in both directions with full air coming out the panel vents. All fixed.
Your suggestion saved me a ton of dash disassembly. Many thanks. Happy new year!
Old Dec 29, 2021 | 11:15 AM
Vinny G-the EX man
That’s great, I know how frustrating it can be when the the ac only blows from the defroster. Great catch !!!
Varro
Oct 10, 2016 06:21 PM
ATF-250
Jul 11, 2016 06:13 PM
chuddyrudd
Mar 20, 2015 07:25 AM
jefxxo
Aug 20, 2009 04:07 PM
ranger714
1983 - 2012 Ranger & B-Series
Jun 19, 2009 09:37 AM
