4 On The Floor Problems!!
Old Dec 27, 2021 | 01:03 PM
burgandy's Avatar
burgandy
Trailering
Exclamation 4 On The Floor Problems!!
I would greatly appreciate any insight someone may have on a 4 speed manual transmission clutch issue. I have a 59 F-100. My clutch was not engaging or disengaging. This lead me to replace the slave cylinder and the line that runs up to the primary. I have bled all the air out and still having issues. I cannot get the clutch to disengage in reverse and in all my forward gears the clutch changes where on the clutch the flywheel is engaging (top bottom or middle). I have reached the end of my knowledge and cannot think of what could be causing continued issues.
Any insight or information will be greatly appreciated. And Happy New Year!
Old Dec 27, 2021 | 02:28 PM
kenny nunez's Avatar
kenny nunez
Clutch problem
If the clutch pressure plate and disc have been replaced and this is when the problem started then it could be the fork rocker bracket has broken or the pressure plate is not parallel to the disc. Does the slave push the clutch fork? If not then the master or slave are leaking internally.
Old Dec 27, 2021 | 02:56 PM
burgandy's Avatar
burgandy
Trailering
Thank you Kenny. Pressure plate and rocker have not been change. Slave cylinder does release the pressure plate.
Old Dec 27, 2021 | 04:51 PM
kenny nunez
loosen all the pressure plate mounting bolts then remove 1 bolt at a time then put a flat washer under each ear of the clutch plate and tighten them up. Then see if the clutch will release.
Old Dec 27, 2021 | 05:09 PM
kenny nunez
Question Clutch problem
Is the transmission the same one that has always been in the truck?
Old Dec 28, 2021 | 09:40 AM
burgandy's Avatar
burgandy
Trailering
Yes Kenny. It’s all original. The clutch started the feel as it fluid was leaking past the slave cylinder. This led me to replace it and the line. And I believe I’ve bless all air from the line but clutch still has same problem.
Old Dec 28, 2021 | 11:37 AM
kenny nunez
If you can rig a “come a long” to pull the fork instead of the slave will the clutch release?
Old Dec 28, 2021 | 03:50 PM
burgandy's Avatar
burgandy
Trailering
Good idea! A new development is that the mechanic guy I trust told me it is my master cylinder. Hopefully that solves it. Thank you for all your help and advice.
Old Dec 28, 2021 | 05:07 PM
kenny nunez
Clutch problem
There is a place called White Post Restorations in Vermont that repairs the cast iron slaves and masters by boring out and installing a stainless steel sleeve and also rebuilds them. Needless to say not cheap but will be the last time you will have a problem with them.
Old Dec 29, 2021 | 12:30 AM
burgandy's Avatar
burgandy
Trailering
That is good to know Kenny. I just bought a new one on LMC. Hopefully it fits!
Old Dec 29, 2021 | 06:10 PM
spurredon's Avatar
spurredon
If LMC doesn't work out, you can get one from NAPA online. 1959 Ford F100 1/2 Ton - Pickup Clutch Master Cylinder | NAPA Auto Parts (napaonline.com)
Tiggie
1983 - 2012 Ranger & B-Series
Sep 5, 2015 08:11 PM
Ron Carlill
May 6, 2012 07:44 PM
jas88
24
Mar 14, 2011 11:29 AM
Rebel Ford 95
Mar 30, 2008 02:24 PM
1eye
Dec 22, 2007 10:17 AM
