42 pin connector
Old Dec 27, 2021 | 12:22 PM
cjgray1974's Avatar
cjgray1974
42 pin connector
Does anyone have a pin breakdown of the 42 pin connector? My glow plug relay wont work unless i run a jumper from the ground side of the relay to the battery ground. I thought if I could test it at the connector i would narrow down where the wire might be broke at.
also a used auto ingenuity to determine that the PCM is telling the glow plugs to turn on. TIA
Old Dec 27, 2021 | 01:08 PM
helifixer's Avatar
helifixer
Old Dec 27, 2021 | 01:12 PM
helifixer's Avatar
helifixer
Old Dec 27, 2021 | 03:02 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
There are some minor differences between the 2000 MY and your 2002 MY when looking at the 42 pin connector.
Please see posts #4 and #5 at the link below.
Link: https://www.ford-trucks.com/forums/1...l#post19638155
Old Dec 29, 2021 | 11:02 AM
cjgray1974's Avatar
cjgray1974
Thanks guys. That helps a lot!!
SLOgoing
Apr 11, 2021 06:51 PM
Yahiko
Aug 27, 2017 09:46 AM
bbender85
Oct 8, 2013 05:10 PM
surfpunk
Jan 22, 2012 07:31 PM
j tate
Dec 4, 2006 06:11 PM
