FORSCAN and injector wiring
2004 F350, 6.0: I replaced all three pigtails to the FICM, and had the FICM repaired .. Ran the FORscan injector electrical test twice and no errors found, I do think then my wiring is correct and not cross wiring to the pigtails. Looking for assurance my logic is correct,, or if you know another way I can test my wiring before starting the truck.
thanks
thanks
The following users liked this post:
There are breakout boxes on the market (e.g. 80-pin Mercury) that work on Ford and International, but you're looking at several hundred dollars. I own my share of breakout boxes, but generally use my 20-yr old Fluke Automotive 88 DVOM, Ohms Law, and electrical diagrams to validate pin outs on harnesses I've built -- this is an easy (but time consuming) last step to protect the FICM or injector (solenoids) from frying.
Mgilkeson83
18
10-10-2021 11:45 PM
SpringerPop
11-20-2013 08:07 PM
