E40 torque converter
Old Dec 24, 2021 | 01:29 PM
Bigfoot123's Avatar
Bigfoot123
I just serviced my 1996 e40d transmission, new gasket, filter and solenoid pack. I drained my torque converter but when I was putting the drain plug back in it seems to bottom out with a few threads still showing. Should this plug tighten all the way against the torque converter or is this normal? I don’t want to strip it.
Old Dec 24, 2021 | 02:19 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Mine has a few showing, was yours screwed all the way in when removed.
Old Dec 24, 2021 | 02:26 PM
Bigfoot123's Avatar
Bigfoot123
Ok thanks, that makes me feel better! I appreciate you looking. To be honest it was dark when I pull it out so I’m really not sure. I should have paid closer attention, this was my first time.
Old Dec 24, 2021 | 06:34 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I completely understand not wanting to damage the converter. You don’t want to have to remove the transmission to replace the converter if you don’t have to.
Just for the future … you have an Electronic 4 speed OverDrive (e4od/ E4OD) transmission. Not an e40d, E40 or Ed40.
Old Dec 24, 2021 | 07:33 PM
z31freakify's Avatar
z31freakify
It's an NPT type thread, you can use gasoila or Teflon tape and snug it so there's no leakeage.
Old Dec 24, 2021 | 08:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't recommend this. If some gets loose inside the transmission it can block an orifice or stick valve. The thread is designed to seal without adding any sealant. Don't add any.
Bigfoot123's Avatar
Bigfoot123
I will try that if it leaks, thanks. I just snugged it up but it worried me it hadn’t bottomed out.
Old Dec 24, 2021 | 10:34 PM
z31freakify
Good to know, done many like that but will follow your advice.
Old Dec 25, 2021 | 01:19 PM
Mark Kovalsky
If you're really careful and don't get any inside the trans it's fine. If a small bit does get loose inside it has the potential to do a lot of expensive damage.
al0311
Aug 22, 2015 08:58 PM
makthenif
Mar 8, 2011 04:07 PM
Gage2502
May 25, 2008 06:54 AM
AlienMotorsports
Jun 19, 2007 12:50 AM
