glow plug click?
Old Nov 26, 2003 | 07:30 AM
frenchf250's Avatar
frenchf250
glow plug click?
I have a 1992 f250 with a 7.3, when I start it up it cranks an awful long time
but it does start. My question is: Probably 8-10 sec. after the wait to start
lite shuts off I here a series of ticks and the day time running lites blink.
What does this mean? Should I wait for this click to start or try after the
lite goes off?
thanx
Ian
Old Nov 26, 2003 | 08:05 AM
pnose's Avatar
pnose
The clicking you hear is normal,its the glo plug relay finishing the heat cycle.As a rule when the wait to start light goes off the engine is ready to start.A lot of cranking could be some bad glo plugs,batts not up to par,or air in the fuel system.
Old Nov 26, 2003 | 10:35 PM
Spectramac's Avatar
Spectramac
I have seen a couple of guys that wait through the clicks, but it is not necessary.
Old Dec 3, 2003 | 03:11 PM
spearfisher's Avatar
spearfisher
I have the same truck & mine starts easier if I wait til the glow plugs click off as well. It was really hard to start before I changes the glow plugs. I am on my third set now at 190,000 miles & it seems that the aftermarket ones I bought doesn't last as long.
Old Dec 4, 2003 | 06:07 AM
pnose's Avatar
pnose
Srearfisher,I would recomend only Motorcraft which are Beru glo plugs,they are a better quality than anyothers ive seen or used.They last longer and hold together better(broken tips can cause expensive headaches).
Old Dec 4, 2003 | 08:46 AM
ditch witch's Avatar
ditch witch
I have a set of GP. Their International Part # 1804211C2, on the tag is says made in Germany. How do I determine if these are good, bad or indifferent? Thanks.
Old Dec 4, 2003 | 09:04 AM
pnose's Avatar
pnose
Below the treads on the gp you should find the name of the gp. BTW, Beru is made in Germany
