Problem refilling coolant--could this damage something?
Old Dec 19, 2021 | 05:31 PM
Its_Green's Avatar
Its_Green
'77 F150 with the 300 six. Just had a weird coolant issue and wanted to check in. I've had my cooling system apart (on this truck and others) a few times and never had any trouble refilling it. Always the same process--refill coolant, start engine with rad cap off, top off once the thermostat opens. Easy. Today I replaced the heater core and refilled it again. This time when the thermostat opened there's a big blast of steam out of the radiator and the coolant vanishes. I had to put over a half gallon in to bring it back up to the visible level in the radiator. Now it seems to be fine and everything's working correctly.
I'm assuming there was a giant air bubble in the block and it boiled what coolant was in there. Any chance I damaged the head? Never had this happen before. Ambient temperature was around freezing. Going ahead if I have to do this again, should I try to bleed the block by popping the heater hose off the thermostat housing?
Old Dec 19, 2021 | 06:35 PM
mwoj's Avatar
mwoj
Maybe a bunch went to fill the heater core?
Old Dec 20, 2021 | 04:16 AM
Ozzie H.'s Avatar
Ozzie H.
I doubt that you damaged the head. Hopefully, it will be quite a while before the heater core will need to be changed again, but you could try the bleeding process next time to make it a bit more gentle.
Old Dec 26, 2021 | 10:03 PM
lasermike's Avatar
lasermike
Some thermostats have a bleed hole to vent the air trapped behind them. If you installed a new one, it may not have had a vent or you may have put it down instead of up. I bought a vacuum filler a couple of years ago, it pulls a vacuum on the system then uses that to pull coolant from a 5 gallon bucket. No more wondering if there is trapped air and no more coolant burped into the fan and being sprayed all over the engine.
Michael
Old Dec 27, 2021 | 05:24 AM
User 71024's Avatar
User 71024
I've never had much trouble with the old stuff, when we started going to transverse engine with electric fans a lot of cars had issues filling so we got in the habit of poking a hole in the thermostat with an ice pick on the t-stats that didn't have there own vent. If your's wants to be stubborn poking a bleed hole won't hurt a thing. As for your head, I can honestly say I have never had a 240 or 300 with a warped head in my entire life so they must be pretty strong. I owned a radiator shop for 20 years.
NM33013
Apr 6, 2018 08:12 PM
roughridn_sob
Jan 7, 2017 02:28 PM
tkerkela
Oct 4, 2016 02:27 PM
grnburg
Jul 16, 2006 09:27 PM
bpsigchi
Oct 11, 2005 12:49 PM
