Filling Block with Coolant for First Time Startup
I am almost at the point where I am going to be starting my 1992 F150 5.0 soon for the first time after my re-seal job. Since my engine was out and on a stand, I of course no longer have any coolant in the block itself. Before startup I really want the block to be full of coolant to prevent it from getting too hot until the thermostat opens. How would I go about doing this? Can I disconnect a heater hose and fill it through that and then fill the radiator and keep adding when needed? Any advice or input would be much appreciated. Thanks.
Disconnect the uppermost heater hose at the engine end and fill the radiator as normal. Reconnect the heater hose when coolant comes pouring out.
Some engine blocks will fill right up without doing this. I found that my 4.9 six cylinder was a beast to fill until I tried this method. I realize you have a 5.0.
I'm not sure who you are asking. I meant to just fill it at the radiator(as usual) and when coolant comes pouring out where the top most heater hose hooks to, reconnect the heater hose. The system should then be fairly full. As mentioned check the level again after running.
grnburg
07-16-2006 09:27 PM
bpsigchi
10-11-2005 12:49 PM
