Spark Plug gap question
Old Nov 4, 2003 | 05:13 PM
71ranchero500's Avatar
71ranchero500
I just put a HEI distributor in my 5.0 and i talked to a guy in my auto shop and he said that my gap should be gapped to about .044 or .045 compared to the original .035 i was just wondering if this sounds right before i go do it and have to do it over if its not
Old Nov 4, 2003 | 06:28 PM
TheWiz427's Avatar
TheWiz427
.045 should be ok! I would'nt go any more than that.
Old Nov 4, 2003 | 08:19 PM
71ranchero500
Thanks Sounds good to me
Old Nov 5, 2003 | 12:16 AM
71ranchero500
Could the gap difference cause pinging since its not gapped enough?
The timing is set at 6d
I use 91 Oct
and have all new everything
I get pinging when I punch it from a stop ive noticed it more lately and im guessing it from the gap?
Old Nov 5, 2003 | 12:54 PM
jwtaylor's Avatar
jwtaylor
Is the heat range the same? Most electronic ignition units from ford put the plug gap at .044 so your okay there. Was the distributor set up for your engine specs, I know with some distributors as yours the company will actually set it up for your application? I would guess not looking that your pinging is more related to the distributor advance more so than the plugs. Just double check your timing is at 6BTDC or so and that the timing marks are correct on the damper in relation the tdc point of your pistons. Hope this helps some, later
Old Nov 5, 2003 | 07:48 PM
71ranchero500
ok fixing the spark plug gaps seemed to help out a big i didnt puch it since but its all right
The Stock Point would still have pings on heavy accel but im kinda use to it
r_reed
Sep 30, 2016 09:48 PM
ecoboostguy
2009 - 2014 F150
Nov 21, 2012 04:52 PM
Broncocustom1219
Feb 11, 2005 03:12 PM
pacer88220
Feb 5, 2005 01:26 PM
fcarruth
1978 - 1996 Big Bronco
Jan 2, 2004 08:07 AM
