I have always had my gap @ .42 per Haynes, Chilton and Mitchell but have read so much on this forum about guys using between .52 and .56. I do not have my sticker in the engine well so I am going by the books. What are the benefits to such a large gap and what are the draw backs ? Should I just keep it the same or what ?
My Chiltons Truck Manual say's .044, but I guess .042 is close enough. The only way to find out if a larger gap will help, is to try it. Ignition system needs to be in good shape though (wires, cap. coil, etc).
Do you have the stock coil or aftermarket. I wnet with an MSD TFI coil and opened them up to .060 and advanced the base timing a little. Helped a little in the mpg department. Stock is .044 I guess the drawback in opening them up more is that the plug won't last as long.
Many factors come into play while trying to determine the gap. MSD says around 50-60 or so if I remember correctly . The advantage to opening the gap is as the electrodes get further apart the spark jumps a bigger gap which has a better chance of igniting the a/f mix (larger area of spark exposed to the a/f mix). Add the higher spark voltage and multiple spark and the chances of a misfire are greatly reduced while promoting more complete burn. It takes a little trial and error to get it perfect, I open the gaps till I notice a slight miss then go down from there 005-008. This will give you whats works best in your application. I have run MSD on all my trucks 78, 2 79's, 87 and 91 MPG usually increased 1-2 mpg and the idle was much improved on the earlier trucks and starting was faster but thats about it.
