spark plug gap
Old Nov 5, 2003 | 12:06 PM
chas4x4's Avatar
chas4x4
spark plug gap
If you open the gap on spark plugs does it make the plug run hotter or colder or what difference will there be? I have a F-250 W/351 I have put colder plugs in and it still pings on hills and hard take offs.
Old Nov 5, 2003 | 12:17 PM
Kemicalburns's Avatar
Kemicalburns
check your timing, this could be your problem. whats it set at now? also the gap on your plugs should be at .44
Old Nov 6, 2003 | 06:59 AM
chas4x4's Avatar
chas4x4
spark plug gap
Thats what I have them set at now and the timing is set where the book calls for.I'll try the next grade of gas.
Old Nov 6, 2003 | 09:14 AM
Kemicalburns
When you set the timing had your removed the spout connector. other wise the computer will try to adjust the timing while your turning the distributor.
Old Nov 6, 2003 | 09:35 AM
jimandmandy's Avatar
jimandmandy
Pinging could be from carbon buildup. Run a dose Chevron Techron treatment in the gas tank. That cured the pinging that my Ranger had. It was needed about once a year.
Jim
