Transfer cases.
Dec 16, 2021 | 03:47 PM
Transfer cases.
I'm Iin a bit of a time crunch here, and I don't have my truck at the moment.
will a tcase from an 07 6.0 with manual on the floor 4x4 work in my 05 5.4 esof.
I'm hoping its possible to just swap over the esof parts?
Any info is appreciated!
Dec 16, 2021 | 04:27 PM
Sure will if you swap the input shafts....
Dec 16, 2021 | 05:31 PM
Dang. I was wondering that. I figured the diesels had a different t case do to the shafts, but I wasn't sure. So it has to be a gas T case then.
what about the manual to esof aspect of it?
Dec 16, 2021 | 08:51 PM
They should both be 5r110’s. Same shaft, bolt in. You will need the manual lever and linkage, the boot, and a knife to cut out the flooring but it all just bolts right in. You’ll also have to manually lock in the hubs like a real man and truck
Dec 17, 2021 | 09:39 AM
I would keep it manual shift and swap the lever, linkage and boot over, its far better than the electronic shift.
Dec 19, 2021 | 11:33 AM
Quote:
Originally Posted by
00t444e
100% agree with this when you have the choice.
Dec 19, 2021 | 08:10 PM
“You’ll also have to manually lock in the hubs like a real man”.
That’s some good stuff right there.
Dec 19, 2021 | 09:19 PM
Both of my trucks are MANually operated.
it looks like I won't be swapping T Cases. It's the front drive shaft that's destroyed.
dumptruck denny
Apr 22, 2021 03:06 PM
jimmy wade
Aug 2, 2018 09:20 PM
dumptruck denny
Nov 20, 2017 04:50 PM
preppypyro
1997 - 2003 F150
Jul 28, 2017 12:18 AM
lenrsmith
Mar 2, 2004 09:41 PM
