Disabling airbag/seatbelt errors from rear seat removal
I've got a 2021 F350 supercab that I've removed the rear seats from. This produced seatbelt and airbag errors, which means that the front airbags no longer work (I'd like hose to still work!), and the vehicle can't pass inspection in my state. I need to clear/bypass these errors, and I'm not at all worried about the legality, since there's no rear seats for any passengers to sit in. Can anyone provide instructions for how to do this?
There are two empty plugs now that I've removed the seats - one with two holes, and one with four holes (photos below). I see airbag/seatbelt "emulators" and bypass resistors online. Can anyone tell me how I would plug these devices into the four-hole plug? Would I need two resistors, one for each pair of holes?
Thanks!
Thanks!
The Ford dealer confirmed that the airbag error generated by removing the rear seat disables the entire system, even the front airbags. So even if the emulators are not 100% guaranteed to work, they're better than what I've got - unless someone else has an alternative approach to suggest. My local mechanic (not the dealer) thinks that removing just the seat belt tensioner from the seat and plugging that in will work. I'm considering giving that a shot.
I never imagined this would be a problem - especially in a work truck! I grew up with vehicles, where you could pop the seats in and out, whenever you needed to. I certainly value the safety features of newer vehicles, but it seems silly that they didn't design this system to be easily turned off when the seats are removed.
I think your local mechanic may be correct. Having the seat belts hanging around wouldn't be too much of a problem would it? You are going to have to bolt the side pieces in correctly. I don't think plugging them in and then throwing them under the carpet is going to work. You said they were mounted to the seat, so I am not sure if you can mount them to work correctly or not.
The following users liked this post:
Johnny L
07-26-2016 11:42 AM
