2020 drafty cab
Old Dec 9, 2021 | 08:57 AM
mewaschuk's Avatar
mewaschuk
Question 2020 drafty cab
anybody else notice cold air, draft in the cab now that winter is back again? seems more prevalent when making turns or on windy days. driving on a straight road, not so much. it's enough that even with the heat up and fan on medium-low you can feel the cold air blowing past. i cannot figure out where it's coming from 🤨😒
edit: crew cab
my 2014 was the same crew cab config and never had this problem
Old Dec 9, 2021 | 09:08 AM
Beast2.0's Avatar
Beast2.0
You have a Crew cab? I used to experience this when I worked out of an E-350. There is a lot of dead air space behind you. whenever I would make a turn, I would get a blast of cold air from the back. My trick was to crack the back door so it the warm air would push the cold out. Maybe crack the slider window or rear window.
Old Dec 10, 2021 | 09:52 AM
HarveyTruck's Avatar
HarveyTruck
Well we don’t get much winter here but here’s something I’ve noticed on mine. When I go through the drive through car wash with the blow dryers I can feel the air forced through the HVAC vents if I have it set to outside air (not recirculate) especially the floor vents. I suppose if the outside air was being forced hard enough such as winter wind up north you might feel it.
dhatt1964
1997 - 2003 F150
Jun 27, 2021 08:54 AM
jgarrison31
Dec 8, 2017 05:30 AM
Myf350sd
2009 - 2014 F150
Dec 17, 2010 01:04 PM
TaosCowboy
Dec 7, 2004 05:03 AM
tom1
Feb 5, 2002 04:57 AM
