quicker cab warm up
Old Jan 28, 2002 | 09:52 PM
tom1's Avatar
tom1
Post quicker cab warm up
this won't defrost the windshield but it sure warms up the seat faster. after cold start up use the AC MAX at high heat setting it recycles the air from inside the cab and not outside colder air. it works!! helps keep cab fresher too!! (fumes)
Old Feb 1, 2002 | 12:23 AM
bhmadsen's Avatar
bhmadsen
quicker cab warm up
If you really want it to warm the cabin quick plug it in for a couple hours. If you leave the heat control set to defrost/hot when you shut it down it will also keep a big enough spot of frost open allowing you to drive right away.
Old Feb 4, 2002 | 04:51 PM
CypressTurboIDI's Avatar
CypressTurboIDI
quicker cab warm up
just do what I do and never turn the dang thing off after all diesels were originally designed to run all dat every day for drilling purposes
Old Feb 5, 2002 | 04:57 AM
alanscott's Avatar
alanscott
quicker cab warm up
theenforcer
Mar 23, 2013 05:13 PM
audkay
Nov 28, 2010 05:09 PM
Ace!
General Diesel Discussion
17
Jan 31, 2007 07:26 AM
dieselbogging
27
Jan 5, 2007 09:31 PM
Lynnekurt
1997 - 2003 F150
Jan 6, 2004 03:36 PM
