I want a switch for the overdrive off switch that I can mount in a pannel on my dash, anyone know where to get one or make one? Its for my 2002 f 250 xlt supercab 4x4 5.4 gas.
I'm replacing the colmn shifter with a winters sidewinder mounted in my lower dash
You need a momentary contact switch. Any electronic supply place should have one.
Thanks for the reply I was nieve thinking someone sold a new od switch pre wired to replace mine to the dash, I have bought a momentary contact switch but it has 6 wires and I need to figure out which 3 to use and where to connect them im still learning more about the switch
it seems hard to find a wiring diagram .
My real question is how to wire a momentary contact switch for a 4r100 at
this was challenging to me but i like the results, got it done. Od on indicated by the blue light ring, od off has no light Android head unit, and a cable shifter no colmn
Reason: Adding a photo
