Adding supp heat?
Old Dec 6, 2021 | 05:52 PM
Flyct's Avatar
Flyct
FTE Community Team
DELETED. POSTED REPLY TO WRONG THREAD.
Old Dec 8, 2021 | 11:18 AM
KU4OJ's Avatar
KU4OJ
Then there's these things at under $100 and a couple hours work. An upfitter relay controlling a massive relay might be helpful.
https://smile.amazon.com/RAMPAGE-PRO...8983679&sr=8-2
Old Dec 9, 2021 | 09:53 AM
Daddy454's Avatar
Daddy454
Originally Posted by Marinerjoe
Daddy, unless you have the garage door open, or some serious ventilation, or a detached garage, that’s not something I would recommend as a safe practice. Just my two cents.
Joe
No worries Joe,it's detached and I open the bay door as soon as I walk in.
Old Dec 9, 2021 | 10:30 AM
ThumbsUp's Avatar
ThumbsUp
Still not something I would do. You will still breathe CO as you walk in and get in your truck and there will also be some in the cab of the truck. Maybe not enough to harm you in the short term but maybe not so good over time. If your garage is close enough, it maybe good to use a remote and open the garage door when you start your truck.
Old Dec 9, 2021 | 10:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by chadstickpoindexter
I didn’t add it to mine. If I could go back I would have added it, but I didn’t know any better… I did add the engine block heater though. I have only been in temps as low as the mid to high 20’s so far but with the engine block heater plugged in for a few hours I haven’t had any concerns. The EOT starts higher/warmer than it would without the heater and seem to climb pretty fast once I start driving. I’m about 4 miles from work and drive through several red lights to get here, so no chance for running higher RPMs but the air coming from the vents are warm by the time I get here. I do have a high idle wired into one of my upfitter switches so I typically remote start the truck when I’m putting my boots on to walk out the door. I leave the high idle engaged so when it cranks the RPMs kick up to 1200, then I walk out and unplug the truck and roll the extension cord back up. So far my EOT has been around 70-80F by the time I get in the truck and get settled and pull out of the drive. Around 100F I can start feeling warm air pretty good and it doesn’t take long to get there. I just got a Banks IDash, so I’m curious to see what my ECT’s actually are too when using the engine block heater.
Adding the engine block heater is less expensive and easier than adding the supplemental heat aftermarket as far as I understand.
When it is -10F or colder, plugging your truck in for 4 hours or longer helps with starting, but not with getting heat. On my truck and my (pre pandemic) commute, I won't get anything resembling heat until I've gone 12-15 miles.
Dress warm, crank up the seat heater to TOASTY and hope for the best.
Old Dec 11, 2021 | 10:46 PM
KU4OJ's Avatar
KU4OJ
Toasty is right. With all 3 LED's turned on my heated seats will put grill marks on your butt!
Old Dec 11, 2021 | 11:03 PM
TheFarm1019's Avatar
TheFarm1019
Glad you posted this. I just picked up my 2022 6.7 also and I told myself I didn't need the supp heat until it took 20 min to get decent heat at -5F degrees the other morning lol
Old Dec 13, 2021 | 12:46 PM
CO_Native's Avatar
CO_Native
Well crud, I ordered mine w/o the supplemental heater thinking the engine block heater would suffice here in Colorado if I let the truck idle for 10-15 minutes in the morning before leaving to clear the windshield. Oh well, live & learn I guess! Good info in here, thanks for sharing y'all!
Old Dec 13, 2021 | 12:56 PM
rhino_160's Avatar
rhino_160
15 min warmup def helps. It’s just now blowing hot air when you get in.
28° this morning and I did a 10-12 min warmup. Seats were fairly warm and the chill was starting to knockoff. Prolly 5 mins into driving the heat was coming in decent
Old Dec 13, 2021 | 01:12 PM
CO_Native's Avatar
CO_Native
Oh ok, that sounds acceptable for me then. My 19 Tundra takes about that long to heat up so I'm pretty used to it. I was expecting 30+ minutes the way some folks talk about the 6.7 taking "forvever" to heat up.
Old Dec 13, 2021 | 02:16 PM
75Mike's Avatar
75Mike
High idle with the block heater makes a huge difference on heating time. Gotta love remote start and remote control outlet for the heater.
Old Dec 14, 2021 | 10:22 AM
rhino_160's Avatar
rhino_160
it’s a good 20+ mins to get fully heated up as far as engine temperature but for heat out of the vents it’s what I described.
I can feel vent hear about the first sign of blue on the temp gauge
Old Dec 14, 2021 | 11:24 AM
  #28
chadstickpoindexter's Avatar
chadstickpoindexter
Yeah the temps so far have only been high 20’s but in these temps with the engine block heater plugged in I am getting good heat from the vents by the time I get to work, less than 4 miles away. Of course the cab isn’t heated but it’s warm air blowing out for sure. Where I am temps often drop to the mid to low teens and occasionally into the single digits but I have never seen lower.
Krazy1
Feb 10, 2020 10:19 AM
Diesel cat
Dec 4, 2011 10:05 PM
Scolesy8
Apr 17, 2008 04:09 AM
tip49
Aug 30, 2007 10:21 PM
