I ordered a new F350 truck this week and if anyone has received a similar 2022 could you post your payload please. The only option with any significant weight that I didn’t order is the moon roof. I’m hoping it will be at least 3,400 lbs since my similar equipped 2020 Lariat is 3,484 lbs.
2022 F350
Crew Cab Short Bed
6.7L diesel
FX4
5th wheel prep
Upfitter Switches
Splash Guards
Rapid Heat Cabin heater
I ordered a new rep truck this week and if anyone has received a similar 2022 could you post your payload please. The only option with ant weight I didn’t order is moon roof. I’m hoping it will be at least 3,400 lbs since my similar equipped 2020 Lariat is 3,484 lbs.
2022 F350
Crew Cab Short Bed
6.7L diesel
FX4
5th wheel prep
Upfitter Switches
Splash Guards
My 2022 is equipped almost identically to yours and its payload is 3383. Mine is a 2022 F350 Crew Cab Short Bed Platinum, 6.7, FX4, 5th wheel prep, up fitters, 397 amp alternator with rapid heat supplemental heater, snowplow prep, roof clearance lights, and NO sunroof.
Thanks! My guess is mine might come in right at 3400 since it doesn’t have Snowplow prep with heavier front springs. No need for snowplow prep here in Florida.
There was a link where you could see every option change the dry weight of 5e truck but I can’t find it now.
search ford body builders guide.
It takes some looking but option weight is there
