Check Engine Light
Old Nov 30, 2000 | 06:23 PM
Pastmaster's Avatar
Pastmaster
Check Engine Light
Old Dec 2, 2000 | 03:58 PM
rpage's Avatar
rpage
Check Engine Light
I have a 1994 F150 5.0 140k mi.The check engine light came on and stays on.Any suggestions.rpage@gdi.net
Old Dec 2, 2000 | 09:48 PM
PAUL_2's Avatar
PAUL_2
Check Engine Light
All you need is a small jumper wire to connect the Self test input wire & Signal Return wire of the EEC IV Check Connector . Most all DIY auto repair manuals outline the procedure for retrieving trouble codes from the Ecu . You can also do a search here for posts that have links to online diagrams & descriptions of the test procedure .
