Mud flaps
Old Nov 28, 2021 | 08:45 AM
Hunter23's Avatar
Hunter23
Mud flaps
Best 2022 sd mud flaps srw
Old Nov 28, 2021 | 08:56 AM
.Axl's Avatar
.Axl
Ford, Weathertech & Husky all have mud flap options. (I'm sure there are more) Not sure what's best for you.
Old Nov 28, 2021 | 09:47 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
I put Weathertech on mine. I will say this, with the factory wheel well liners on the front, I needed to use longer screws on a few.
Old Nov 28, 2021 | 09:56 AM
Beerleg's Avatar
Beerleg
when i put them on my '19 i looked at a lot of threads, and went with gatorbacks and have been happy.
research the threads, they have been discussed. there are a few options availible in flaps from diffrent makers.
Old Nov 28, 2021 | 10:06 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I put the oem accessory Ford flaps on mine, they've been okay so far, but they are not real substantial.
Old Nov 28, 2021 | 12:28 PM
LabCab's Avatar
LabCab
Duraflap for the win! I have had them on my last 4 Superduties. Great company and product.
Old Nov 28, 2021 | 02:42 PM
SomethingRandom's Avatar
SomethingRandom
Depends. Are you only using your truck as a tow vehicle? Exclusively a pavement princess? Do you actually go off road and not just gravel roads?
for towing at min I would pick Gatorbacks.
pavement princess: OEM/Husky/Weathertech
off road: Rockblokz
Old Nov 28, 2021 | 03:33 PM
Preskitt's Avatar
Preskitt
I went with WeatherTech...fit was excellent and install was easy...couldn't be happier.
Old Nov 28, 2021 | 03:38 PM
zeroo's Avatar
zeroo
I went with weathertechs again, cheap, easy, looks ok, but I am thinking I want those expensive ones. Cant think of the name right now…
just remembered the name, gatorbacks.
Old Nov 28, 2021 | 04:15 PM
scottz99's Avatar
scottz99
Veteran: Navy
I like the Luverne mud flaps:
Front
https://smile.amazon.com/dp/B06XTRY7...duct_details\\
Rear, duals
https://smile.amazon.com/dp/B06XTKGV...roduct_details
Old Nov 28, 2021 | 10:49 PM
powerboatr's Avatar
powerboatr
me to
easy to install
Old Nov 29, 2021 | 03:12 AM
SeniorRVer's Avatar
SeniorRVer
happy with husky so far, easy install, would prefer they be a couple inches lower to the ground.
Old Nov 29, 2021 | 05:11 AM
Hunter23's Avatar
Hunter23
Thanks guys
Old Nov 29, 2021 | 05:52 AM
GNR22's Avatar
GNR22
I put Husky flaps on my '21 as well as my brothers. I drilled the extra optional holes in mine but not on his and they are both very solidly mounted. Conversely to SeniorRVer above, I actually like that they don't hang low. They are low enough to deflect debris down to under the steps, which is all the lower they need to be in my opinion.
Old Nov 30, 2021 | 12:00 AM
MAX4utah's Avatar
MAX4utah
I have Rok Blokz mud flaps. If you plan on leveling your truck and having aftermarket wheels with more offset, they are the way to go. They looked kind of silly IMO when I have stock wheels and tires. My wheels are +12 offset and the flaps cover perfectly.
