Halogen headlight function
Old Nov 27, 2021 | 08:13 AM
TheFarm1019's Avatar
TheFarm1019
I've never owned a 2017+ SD so I don't know exactly how the front headlights function, when turned on are all 4 headlights on at the same time at a lower wattage? Or are the low beams separate from high beams when turned on/off?
im looking at ordering some Hikari led bulb replacements today using some online deals but I don't know if wattage output is an issue or if I need to find bulbs that are designed to be ran on 2 different power levels? Or can I just get 2 of the same pair and it'll be fine?
Old Nov 27, 2021 | 08:19 AM
h20camper's Avatar
h20camper
The SD halogens are 9008/H13 dual filament (low and high beam) bulb. The truck does use a total of four of these . Two on each side. All four bulbs work in unison on low/high beam. In other words, when on low beam, all four bulbs use their low beam filament. Switching to high beam, all four use their high beam. Yes, you'll need four (two pairs) of the same bulb.
Old Nov 27, 2021 | 08:54 AM
Poncho450's Avatar
Poncho450
One guy's opinion on the Hikari: I've had them for quite some time now and really like them. Adjust them right and you should be pleasantly surprised without blinding oncoming motorists.
Here's a video from Headlight Revolution with some good tips:
Old Nov 27, 2021 | 10:11 AM
Back2Gas?'s Avatar
Back2Gas?
Very good to know, thanks for posting the video!
Old Nov 27, 2021 | 10:39 AM
Poncho450's Avatar
Poncho450
I learned a couple of things from it. Judging by the fact that I've not been flashed, maybe the tips worked.
Old Nov 27, 2021 | 10:46 AM
TheFarm1019
https://www.youtube.com/watch?v=OIow5YgdRro
Thanks! So I take it the Hikari bulbs have a high/low function too?
Old Nov 27, 2021 | 11:02 AM
Poncho450's Avatar
Poncho450
Yes. It's been a while but I believe they're H13? All four bulbs have both the high & low beam function.
Grass Lake Ron
Dec 4, 2021 12:36 PM
paker
1997 - 2003 F150
May 31, 2021 03:57 PM
jbravata2
16
Aug 21, 2015 07:15 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
fauxexplorer
Oct 2, 2001 05:20 PM
