Fuel Filter Intervals and Pressures
I know a lot of you guys now run fuel pressure gauges so I’m curious what kind of drop in pressure you are seeing as the filters get dirty and if anyone is going beyond the typical 10k mile recommendation.
My data point. Was approaching 10k miles on my filters. Was considering going to 15k. Hadn’t plugged in the Edge cts for a while as I’m afraid someone will steal it. Hot idle pressure was a nice steady 57-58. A somewhat brisk acceleration around 10psi of boost it was down to 50. Full pedal it was setting off my alarm and getting down to almost 45. So that prompted a filter change. Now mild acceleration is around 55psi and full pedal is 50-51. Idle is still 57-58.
Filters were stock Racor. Truck has a blue spring that is about 2 years old.
Filters didn’t look bad but I’m sure it’s nigh impossible to see 10 micron particles.
I tend to want 50 psi minimum, with 60 psi being "typical".
You never know how accurate the pressure measurement system is and we will never be watching the gauge frequently enough to catch all the dips, even if the instrumentation has a fast update rate.
45 psig minimum is what Ford published.
I meant 45psi at WOT = 55 psi cruising .
sorry for confusion.
Once towing through CT I observed coolant pressure drop from the at the time 12psi to 4 then 0. I pulled over and found a cracked Y-pipe.
Towing again in TN while pulling away from a traffic light at above med. throttle fuel pressure dropped to 30. I let off and got back on it and at WOT it was going to 0. I milked it until I could stop using only light throttle until I could pull it apart. It was a bad regulator seal. This has happened actually 2 or 3 times throughout the life I owned my dually. It's been a minute but if I remember right, the gauge is what told me my pump wasn't keeping up either causing me to replace it. This is why I recommend a dual gauge, fuel and coolant pressures, on the A-pillar where you easily view it subconsciously.
Top (amber, color of fuel): Fuel pressure
Bottom (red, color of Rotella ELC): Coolant pressure
For the fuel filters, I changed it every other oil change. The gauge never was effected. Maybe I got lucky getting clean fuel.
Totally agree - my fuel pressure gauge caught my fuel pump failure AND a failing (intermittent) fuel pump relay.
My point in my earlier post was to bump the minimum pressure value up a bit, just to be safe.
I haven't ever really benefited from my coolant pressure gauge, but I have one and I see how it could be a big help. I have only had a coolant leak once and it was very small.
I also have not seen any pressure impact over the life of the fuel filters.
lakewood
05-29-2013 04:37 PM
