Tool question
Old Nov 26, 2021 | 10:43 AM
cwtex04's Avatar
cwtex04
Tool question
What impact wrench are you carrying for your 5thwheel and truck lug nuts? I don’t need one very often but it would be nice to carry.
Old Nov 26, 2021 | 10:48 AM
scraprat's Avatar
scraprat
Top Answer: 5
When needed a deep well socket and 1/2 drive breaker bar for taking off the lugs. When reinstalling them I'll use a 1/2 drive torque wrench.
You carry a air compressor with you? I use to but it wasn't used enough and it was just dead weight, now just a small 12v for airing up when needed.
Old Nov 26, 2021 | 11:30 AM
cwtex04's Avatar
cwtex04
I have a Viair 450P air compressor that I carry with me . I also have a torque wrench , sockets and breaker bar . Just looking for a impact to help speed up the process.
Old Nov 26, 2021 | 11:36 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I carry a 1/2" cordless impact wrench and the impact sockets I need for truck, trailer and boat and a torque wrench to finish them off. I'm using a Bauer from Harbor Frieght.
Denny
Old Nov 26, 2021 | 12:51 PM
scraprat's Avatar
scraprat
Top Answer: 5
I forgot about cordless impact I might have to get one it certainly would help speed up rotating tires. Doing everything manually does get old. Thanks for a reminder Denny.
Old Nov 26, 2021 | 01:43 PM
Keokie's Avatar
Keokie
Cordless impacts are a huge help when changing tires by the side of the road. I carry a Milwaukee 1/2 inch.
Old Nov 26, 2021 | 03:00 PM
jsm180's Avatar
jsm180
This one
Dewalt Impact Dewalt Impact
Had it a few years and not picked up the air impact since.
Old Nov 26, 2021 | 03:34 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I carry a Ryobi 18v cordless impact wrench. It is bright colored so if I set it down I can find it easily. It is cheap enough that if I don't find it easily and leave it behind, I just buy another.
I modified a front landing gear hand crank tool to fit into the chuck (1/2" chuck adapter for impact wrenches) in the event I need to raise or lower the lading gear by hand. Now, I can do it by tool...
Old Nov 26, 2021 | 06:24 PM
kshoop1958's Avatar
kshoop1958
Milwaukee M18 Fuel 1/2" Impact Wrench and this:
Amazon Amazon
Old Nov 26, 2021 | 07:30 PM
HRTKD's Avatar
HRTKD
DEWALT 20-Volt MAX XR Cordless Brushless High Torque 1/2 in. Impact Wrench. I haven't had to use it out on the road on the F-350 but I did have to use it to change two trailer tires at the same time at a rest stop. Having the impact wrench really made the job a lot easier. It would have been just like a NASCAR pit stop except that both spare tires needed air.
Now I just need a cordless jack.
Old Nov 26, 2021 | 09:51 PM
senix's Avatar
senix
milwakee cordless 1/2 drive impact.
I carry a 3/4 deep well impact socket and a 21MM deep well impact socket in the case.
One for the truck (socket) and the other for the trailer.
I always take them off with the socket and lightly put them on with the impact and then torque by hand with a star lug nug wrench.
Old Nov 27, 2021 | 10:19 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
+1 on the DeWalt.
Old Nov 27, 2021 | 10:45 AM
HRTKD's Avatar
HRTKD
I've had Dewalt corded and cordless tools for a long time after giving up on Craftsman. My roster of Dewalt tools had momentum and I kept buying that brand. Just to be clear, I'm satisfied with the tools that I have. But Dewalt has some glaring holes in their offering. For example, I wanted a cordless version of my pneumatic right angle impact wrench. Dewalt had absolutely nothing.
This summer I was looking for a cordless staple gun (narrow crown) to use when I didn't have power to run my air compressor for my Bostitch staple gun. I just didn't like the Dewalt options. The specs were different and none of my existing inventory of Bostitch staples would work. My Bostitch pneumatic tools are absolutely flawless and reliable as can be. It's hard to give that up.
If I had it to do over again, Milwaukee would probably be the line I would go with. At this point, I have too many tools and too many batteries to switch away from Dewalt.
Old Nov 27, 2021 | 11:09 AM
scraprat's Avatar
scraprat
Top Answer: 5
I have a Ryobi cordless drill for the scissor jacks when using them that I cut the manual handle off and put the end in the drill. Never thought about cordless 1/2" impact but it's on the Amazon order list.
Old Nov 27, 2021 | 11:21 AM
HRTKD's Avatar
HRTKD
I was using my impact wrench on my stabilizer jacks for a while. The wrench was too much for the bolt head on the jack. It was tearing it up. I switched to a simple cordless drill and that worked better, less noisy also.
