Sponsored by: Real Truck
Front wheel noise
Old Nov 21, 2021 | 01:10 PM
Hopper123's Avatar
Hopper123
Front wheel noise
2003 250 V10 4x4 . I have a rubbing noise from the wheel and can feel a little bumping when I make hard turns in the parking lot. When I jack it up and move the wheel it feels solid no play. Could this be my manual hubs or something else? Not real knowledgeable on this.
Old Nov 28, 2021 | 05:54 PM
Loser1's Avatar
Loser1
Trailering
Possibly a unit bearing? I had each side replaced on my ‘02 at 170ish miles. Same type of diagnosis, felt a little drag at low speeds and could hear what sounded like a faint brake pad grind. They are no longer rebuildable, as they once were. Again, just a guess.
HTH,
Mike
Old Nov 29, 2021 | 07:20 AM
nydiver's Avatar
nydiver
Could be a u-joint in the front axle shaft
Old Nov 29, 2021 | 04:55 PM
redford's Avatar
redford
FTE Leadership Emeritus
Are your lockout hubs locked or stuck?
Old Nov 29, 2021 | 05:26 PM
Hopper123's Avatar
Hopper123
put shocks on a little over a week ago and inadvertently locked the hubs. It only makes the noise when locked so going to order new locking hubs.
Old Nov 29, 2021 | 10:34 PM
Evan_P's Avatar
Evan_P
It’s not the locking hubs. The front axle will make noise if the hubs are locked. The bump when turning is the u-joints binding. Leave the hubs unlocked unless your driving in weather that requires them to be locked.
Old Nov 30, 2021 | 07:00 AM
Hopper123's Avatar
Hopper123
thanks Evan. Just so I'm clear are you saying the noise is normal when in the locked position?
Old Nov 30, 2021 | 08:39 AM
redford's Avatar
redford
Yes, some additional noise and some binding while turning sharply are normal when the hubs are locked.
If you notice the noise when your hubs are in FREE or the noise becomes a loud grind or squeal then you have issues.
Old Dec 1, 2021 | 04:37 PM
Jakerichards1's Avatar
Jakerichards1
The bumping thumping turning hard with hubs engaged gets worse as the outboard u joints start to fail. I have just renewed mine after the U-joints got so bad they nearly caused me to crash when I could not turn out of the turn lane as I accelerated and tried to turn left. I typically leave mine engaged/locked all winter so 4wd is available when I want it.
some unevenness is there turning hard even when new.
dougcepress
Dec 7, 2014 08:16 AM
BAJI26
May 8, 2011 12:25 PM
pittmick
Oct 12, 2010 08:57 AM
Will_01_GT
1978 - 1996 Big Bronco
Dec 21, 2004 03:57 PM
