I think if you check into things on Ford's build site you'll generally find a little circled "i" symbol for the various packages. If you click that it'll tell you which options that package entails.
I would like to know if the black appearance package on the 2022 lariat f-350 has led headlights ,fog lights and tail lights?
thanks
It does, although if I recall is doesn't say it in the package description. But for $4,300 it needs to have something. Anyway, I have the package and it's all LED.
Yes. Same light package as Quad Beam except that the background is dark vs chrome. So slightly different which is why the only build doesn't add the quad beam as it is a different part number. If you try and add quad beam with black appearance, the system will want to remove the black appearance. At least that is what I think but am by no means an expert.
Ford says headlights are LED on the build site and order guide but they don’t specify if the remaining lighting is LED.
Without the black appearance package you have to have the ultimate package and add LED lights separately on the Lariat.
Is there a trim without backup camera? Those things are the law up here in Canuck-land. Also, for years there was no STX package in Canada, although it does exist now. I forget what year it was introduced but it's in the last couple.
All in all cool story bro.
