I have a 2001 F250 with the 5.4, Automatic, 4x4
My ABS light is on and the speedometer doesn't move.
I checked all the sensors. They all show good.
I ran Forscan on it and I am getting VSS voltage and VSS mph on the laptop.
I found that I have 12 volts at the B+ wire and ground on the B- wire at the ABS module.
So, I am leaning in the direction of the speedometer itself, but I want to make sure. Is there any way to test it?
Thanks for any help.
