10000 GVWR on F350 SRW
Old Nov 16, 2021 | 08:34 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by 4B11TX
What configuration are you ordering?
This is what the OP needs to answer. If he is getting a short bed, in any configuration, it won't have the GVWR required for the hydro boost.
Old Nov 16, 2021 | 08:52 PM
rjacobs's Avatar
rjacobs
If its a super cab short bed 7.3, 4.30 gear truck the GVWR is 11,800 which, if it follows the 11,500+ get it, then that combo would get it.
I was going to order that combo and have the build sheet that shows 11,800 GVWR.
I am probably going to order a crew cab short bed and the order sheet on that shows 11,300 GVWR... im not expecting to have hydro boost brakes.
There is a guy in that thread saying his buddy(or his) truck that was ordered as 10k GVWR has VACUUM brakes.
I would expect the OP's truck to NOT have hydroboost.
Old Nov 16, 2021 | 08:55 PM
Grass Lake Ron's Avatar
Grass Lake Ron
My SCLB is 11,800 and has hydro.
Old Nov 16, 2021 | 08:57 PM
4wd6.7L's Avatar
4wd6.7L
A guy in that thread linked above has a 7.3 crew cab short bed with the camper/snow plow prep and he has GVWR of I think he said 11,800 and has it.
Also in that thread a guy comments him and his buddy ordered the same truck, one had 10k GVWR option and no hydro boost, the other was 11800(or whatever) and it had hydroboost.
So I would expect the OP's truck to NOT have hydroboost.
Could you point me to the post# that claimed to have a short bed with a GVWR above 11,500.
Old Nov 16, 2021 | 08:58 PM
4wd6.7L's Avatar
4wd6.7L
Yep, long bed being the important factor.
Old Nov 16, 2021 | 09:02 PM
Spencer Zagurski's Avatar
Spencer Zagurski
Kind of odd a CCLB 6.7L but with a 11400 GVWR won’t have it.
Old Nov 16, 2021 | 09:07 PM
rjacobs's Avatar
rjacobs
I read it again... he had a long bed, my mistake.
And the one where the two guys bought same trucks, one was 10k, the other was 11,400 and both had vacuum brakes.
Will go edit my post so as not to spread mis-information.
HOWEVER I will stick by my other of a super cab short bed getting an 11,800 GVWR... thats IF that truck shows up as the order form shows it with "11,800 GVWR package"... but obviously I have no way of knowing if that truck would show up with hydro boost brakes or vacuum brakes. There is at least 2 guys on the forum with that truck though.
Old Nov 16, 2021 | 09:15 PM
h20camper's Avatar
h20camper
Deleted.
Old Nov 17, 2021 | 04:53 AM
jfcody3962's Avatar
jfcody3962
Over 11,500 gets hydro boost under does not. What configuration are you ordering?
F350 SRW, Short Bed, Diesel
So if I don't order any GVWR "options", what will the default GVWR be on the sticker? 12,400?
Old Nov 17, 2021 | 07:07 AM
RidgwaySD's Avatar
RidgwaySD
Super cab 164" WB is a long bed, not a SC short bed. That wheel base is 148" My SCSB 7.3 3.73 is 11,300 The truck above should have hydroboost but it is a long bed, the only way to get enough gvwr to trigger the addition.
Old Nov 17, 2021 | 07:17 AM
JHForman812's Avatar
JHForman812
11500 is what it will be you cant get 12400 on short bed.
Old Nov 17, 2021 | 07:19 AM
rjacobs's Avatar
rjacobs
****, good catch, glad I didnt order that truck cause if a super cab long bed had shown up after 4-5 months I would have been PISSED. Supercab long bed wont fit in my garage.
I sent the dealer a ford PDF of a supercab short bed build last week as my wife and I were going to order a super cab and that was the build sheet they sent back... I honestly would not have caught that.
Old Nov 17, 2021 | 07:35 AM
  #28
jfcody3962's Avatar
jfcody3962
thanks, so it seems from above the short bed will be vacuum boost no matter what the GVWR option.
I might as well stick with the 10,000 GVWR option then and save some money on registration.
Old Nov 17, 2021 | 07:45 AM
  #29
JHForman812
Yeah unless im reading it wrong, thats how i see it.
Old Nov 17, 2021 | 08:35 AM
  #30
scraprat's Avatar
scraprat
Top Answer: 5
4.30 gears are the deciding factor with his configuration to have hydro. My truck which is basically the same as his has 3.73 and no hydro brakes.
