mutliple question
Old Nov 16, 2021 | 06:32 PM
KAGAN21's Avatar
KAGAN21
mutliple question
hey guys working on rebuilding my 95 f250 460 4x4 auto(e4od i think) and had a few question since im at the part where these parts will affect the truck. background info if helps is that i just bought a detroit truetrac diff for rear, front leaf is 4100lbs rating and rear is 3100lbs rating with also a 3 inch body lift that came with the truck already installed.
1. i was thinking about 35x12.50 tires on 17x9 -19mm wheels and was wondering if that would fit good
2. if i could run 35 inch tires would 3.73 or 4.10 gears be good. truck would be doing light pulling ex. 2 axle trailer with car or truck on trailer and maybe a fifth wheel camper down the road. ( additional info is that im putting on long tube headers, cam and MAYBE a bigger throttle body not for sure if that last one would help.)
thank you in advance.
Old Nov 16, 2021 | 07:56 PM
Wheeler.M1's Avatar
Wheeler.M1
With 35s you should probably stick with the 4.10, especially if you're to be towing with those tires on.
Old Nov 16, 2021 | 08:19 PM
SFaulken's Avatar
SFaulken
I wouldn't even think about anything higher than 4.10 with 35's.
Old Nov 16, 2021 | 08:29 PM
Wheeler.M1's Avatar
Wheeler.M1
I just learned this recently. Large tires also cause frame cracking from the steering box. Right at that steering box cross member. Just a caution. If you do, don't turn while at an idle. Always be moving when you turn.
Old Nov 16, 2021 | 08:32 PM
KAGAN21's Avatar
KAGAN21
ok another quick question is if i don't stick with the 35 and maybe go to a 33, would you guys still recommend a 4.10 gear?
Old Nov 16, 2021 | 08:34 PM
Wheeler.M1's Avatar
Wheeler.M1
Yes, if your towing. 33s and a 4.10 are alright. I get 15-17mpg with that combo. 3.73 if your just towing ba small camper. May struggle going up hill though at highway speed.
Old Nov 16, 2021 | 09:34 PM
SFaulken's Avatar
SFaulken
Building a steering box brace that goes to the other frame rail isn't that big of a deal. You might even be able to buy them. I know you can for many Jeeps.
Old Nov 17, 2021 | 06:06 PM
KAGAN21's Avatar
KAGAN21
thanks for the help guys. the last thing would be does everybody agree that 35x12.50 tires would fit on the truck with a 3inch body lift. mainly with these wheels:
https://www.customwheeloffset.com/bu...7x9-19?brakes=
Old Mar 7, 2022 | 07:41 PM
KAGAN21's Avatar
KAGAN21
boost. anybody know for sure that 35x12.50 tires would fit on a 95 f250 with a 3inch body lift and still have decent clearance?
Old Mar 7, 2022 | 07:55 PM
Wheeler.M1's Avatar
Wheeler.M1
Should fit, I have 33s on stock body 4x4.
Mikethetrucker
Nov 2, 2021 08:28 PM
andrewzx92000
Feb 10, 2018 06:19 AM
00Boss
All Things Towing
Sep 19, 2012 02:27 AM
CobraGT40
Aug 8, 2007 12:04 PM
BMF2001
All Things Towing
20
Jun 19, 2002 07:24 PM
