A new development!
Old Nov 14, 2021 | 03:29 PM
Listor's Avatar
Listor
A new development!
I am starting to think I have an electrical grimlen I just put a new alternator and batteries in my truck!
cruising along today I see I’m sitting at 12 v no Bueno pot nada!
the issue is the large lug I pulled from the alternator and did not disconnect the batteries, should I not get a spark from it?
Old Nov 14, 2021 | 03:43 PM
FinnishStroker's Avatar
FinnishStroker
You must have blown a fuse or fusible link.
​There's 12volts directly from batteries in that lug.
Someone will chime in with some wiring diagrams.
Always unhook batteries when working on electrical system!
(Do as i say,not as i do..)
Old Nov 14, 2021 | 03:57 PM
RacinJasonWV's Avatar
RacinJasonWV
Yeah, it’s amazing the lengths I’ll go to not disconnect the batteries…
I have a special rubber “boot” to put over the drivers side terminal when leaving the passenger side in.
Old Nov 14, 2021 | 04:58 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Are you using "spark" as a means of checking for voltage? You should use a test light or a multimeter, if you have either of those.
The positive terminal on the back of the alternator is the B+ terminal. You should have battery voltage there at the very least when off, and charging voltage of 13.5+ volts when on.
Were the mounts clean and allow the alternator to ground itself?
Make sure the connector is inserted 100% and the pins are not pushed back in the connector preventing continuity.
Check the fused links by the passenger battery. They will look like a burnt pop tart if they are blown.
Check your appropriate fuses in the distribution block.
Perhaps the alternator is dead already. ArmyLifer had a Bosch go out on him 2 weeks after installing it recently.
Point is, there are a lot of things to look into before you can point your finger and call it an SOB.
Come back to us with updates.
Jason, would you mind sending me a text picture the next time you put your "boot" to work? I generally use rags with blue painter's tape on the terminals. Thinking now it might be time to "upgrade".
Old Nov 14, 2021 | 05:12 PM
Walleye Hunter's Avatar
Walleye Hunter
Should you get a spark when you do that? I don't see why you should.
Old Nov 15, 2021 | 04:58 AM
FordTruckNoob's Avatar
FordTruckNoob
Positive result for spark at terminal:
Old Nov 15, 2021 | 06:37 AM
Listor's Avatar
Listor
I know i said spark, but i tested with my multimeter, I did think my meter was bad and quick touch to the alternator bracket and no spark
so i guess i have a series of things, although i did not connect them until last night when i was having a cold one
few weeks ago my horn goes off in the middle of the night , then it stopped, found a blown fuse , replaced it and the horn sounded sick, within a couple of days it just died altogether
then my obd port and cigarette light fuse blew , No apparent reason ( as i think about it) replaced the fuse , had to get the cts3 reset so it would recognized my truck again
Now yesterday i go out to start it and my gpr has died, crank crank crank, screw it plug it in for a bit
then later the same day i no longer am charging!
Like Columbo i am starting to think something else is going on, i will get the alternator tested today, it's only a few weeks old Batteries too
tell me if you think i am crazy or i have some breadcrumbs to follow and if so where is it leading
Old Nov 15, 2021 | 07:29 AM
FordTruckNoob
Sounds like you have a short somewhere. Find and fix that first.
Old Nov 15, 2021 | 07:37 AM
Sous's Avatar
Sous
FTE Emeritus
I agree with Leonard. Some wise words on shorts from Mark K. are below.
First, always probe the back of the connector. Pushing a probe into the end that makes the connection just causes new connection problems. With one probe on the wire that you're testing, touch the other probe to a good ground to check for short to ground, and to power to check for short to power.
Quote source: https://www.ford-trucks.com/forums/1...l#post19916903
and
Disconnect the harness from the PCM and from the transmission solenoid body connector. Now probe the back of the PCM connector and the back of the trans connector to check for continuity from one end to the other. Then with one of the probes still on either of the two connectors, touch the other probe to ground and get a reading. This should read OL. Then touch it to power, preferably the battery +terminal. This should also read OL. If you have continuity and OL to both ground and power you have a good wire.
Quote source: https://www.ford-trucks.com/forums/1...l#post19918627
Not all of the information above pertains to your situation, but I didn't want to hack up the advice from Mark K. It can be misconstrued in some cases when a quote is edited to a point of not making sense.
Also, a quick video on how to back probe connectors as mentioned above by Mark K.
Old Nov 15, 2021 | 08:07 AM
Listor's Avatar
Listor
I see i have some things to look at today, i will be getting the alternator tested this morning and proceed from there
Old Nov 15, 2021 | 10:00 AM
Listor's Avatar
Listor
Well the alternator tests bad but so do the other 3 off the shelf!
Old Nov 15, 2021 | 10:15 AM
FordTruckNoob
Old Nov 15, 2021 | 10:36 AM
Sous's Avatar
Sous
FTE Emeritus
What brand is the alternator you had tested that was bad and are the other 3 on the shelf the same brand?
Sounds like a good time to get your money back and grab a Leece Neville.
Old Nov 15, 2021 | 11:40 AM
Listor's Avatar
Listor
napa reman they had no new ones , turns out their equipment is faulty took the replacement to advanced auto they have a brand new equipment, had to teach the guys how to set it up ( shakes head) anyhow the alternator tested good went ho Put it on cycled the gp’s and she fire right up
not sure what’s going on for worked fine this morning showing 13.2 just sitting here idling
Old Nov 16, 2021 | 03:46 PM
Brother Les's Avatar
Brother Les
Is that a gasser?
I have had enough Diesel Fuel and oil in the valley for many years that you could swim in it. If it did not catch on fire after three years..... I stopped worrying about the 'heat' and/or 'spark'.... Yes, I finally tracked down and plugged all the leaks and cleaned it all up and out.
