A new development!
Old Nov 16, 2021 | 03:48 PM
Brother Les's Avatar
Brother Les
Originally Posted by Listor
Put it on cycled the gp’s and she fire right up
not sure what’s going on for worked fine this morning showing 13.2 just sitting here idling
Many times it is fine to 'declare victory.... and retreat'......
Old Nov 16, 2021 | 04:26 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Originally Posted by Brother Les
Is that a gasser?
I have had enough Diesel Fuel and oil in the valley for many years that you could swim in it. If it did not catch on fire after three years..... I stopped worrying about the 'heat' and/or 'spark'.... Yes, I finally tracked down and plugged all the leaks and cleaned it all up and out.
I remember this photo from years back. Can't remember if it came off this site or another. At the time, it was said to be a block heater cord short.
Old Nov 17, 2021 | 07:35 AM
Listor's Avatar
Listor
Just to close this a little better, I was noticing that i was not hitting the 14v while driving it would hang are 13.6
So a thought occurred to me I had to pull the passenger battery and tray the other day to get to the horn mounting bolt, I was curious if i had not tightened down the battery cables , sure enough they were loose, so pulled them apart , little baking soda paste to clean it all up put it back together and shows proper charging 14.1 running down the road after start up
Note to self: finish things up even when your buddies show up to help drink your beer!
Old Nov 17, 2021 | 07:55 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Don, this is a great lesson learned.
I "usually" put blue or green painters tape on ANYTHING I loosen or remove from service in the truck. The parts I can actually remove, I put in a small bag and label the bag. Things like battery cables, power steering lines, etc... They get painters tape. This helps me remember "hey you, connect this thing before starting the truck". It works well for me as I can look around once I think I am done with the task and quickly notice something in the valley that I forgot.
Both charging voltages are what you would expect from the different situations. So, it appears your alternator and charging system is back to 100% and I commend you for isolating the issue and resolving it in short order.
Old Nov 17, 2021 | 09:05 AM
Listor's Avatar
Listor
Thank you Sir! Sorry not Sir! You worked for a living!
I confound my issues sometimes just being in a hurry Stressed over things that i have no control over!
Wife just had her 2nd knee replacement surgery this week so taking care of her and the truck feels like i don't love her no more LOL
Think it got jealous of me driving the escape all week!
adammdennis11
Apr 21, 2015 07:40 PM
jayro88
Dec 13, 2013 06:10 AM
Charlie01
Apr 29, 2011 03:15 PM
torquemeister
33
Jan 17, 2010 04:11 PM
swaybar
Dec 26, 2008 08:22 PM
