Cab mounts questions
Old Nov 14, 2021 | 11:24 AM
Obscure69's Avatar
Obscure69
Hey
I recently bought new cab mounts to replace the mostly nonexistent ones on my truck. The type I bought are not the best ones, but they were the only ones available at the time, and with some reinforcements I believe they’re going to be fine.
I am getting to the point now where they are almost ready to install, and I wanted to ask if anyone here has used this kind of mounts, what type of reinforcement is needed, and how much to trim away from them before welding them to the floor…
The type of mounts I have…
…and the floor it needs to install to!
Old Nov 14, 2021 | 06:36 PM
fe390pc's Avatar
fe390pc
Well you almost need to double that style up. They tend to crack all around where the rubber mount sits. Now, for welding them, I would wait till you can set the cab back onto the frame so you can line up everything. Good luck sir, you will figure it out I am sure.
Old Nov 14, 2021 | 07:34 PM
Obscure69's Avatar
Obscure69
yeah, that’s kind of what I have heard. I will do that, and hopefully it’ll last for a long time. It’s never going to have a very hard life again, so I am hoping that it’ll be ok. As far as waiting to weld them on, I’d rather not if at all possible. I would like to get it all done while I have the cab off, and laying on its side… maybe I can lift the cab in place, and just tack them… hmmm, I’ll have to think about that
Old Nov 16, 2021 | 08:14 AM
fe390pc's Avatar
fe390pc
I guess you could take your measurements off the frame mounts and then transfer those to the cab referencing the rear mount? Just a thought. Here are my thought for stiffening the mounts;
1) Cut a piece of 1/4" steel plate to fit inside where the hole is for the mount.
2) Use 1/8" steel plate on the inside of the vertical sides.
Weld them in and together so the is transferred to the cab.
Here are the places inside the mount to add material.
Doing this should make them last a long time. I hope this helps, just my thoughts.
Old Nov 16, 2021 | 10:58 AM
Obscure69's Avatar
Obscure69
Yeah, that sounds good, I will try that…
Old Nov 16, 2021 | 11:48 AM
jzjames's Avatar
jzjames
You’ve probably seen this;
Cab Mount Concerns - The FORDification.com Forums
Old Nov 16, 2021 | 12:10 PM
Obscure69's Avatar
Obscure69
Originally Posted by jzjames
yes, but the better ones were not available from the company in germany where I shop… these will have to work, even if I need to mod them!
Matt66
May 29, 2017 07:17 AM
CraigerF100
Paint & Bodywork
Jan 7, 2013 07:20 AM
chefwita64
20
Dec 18, 2012 05:35 PM
jeff80
Dec 25, 2011 03:06 AM
Elvis40
Apr 21, 2011 02:02 PM
