8 Lug wheels -Disc brakes
I have an 8 lug front disc brake kit. My stock wheel hits the caliper. The instructions say to find a newer replacement wheel that will accept the caliper. The trick is it also needs to accept the stock hub cap.
Anybody know a substitute for a 16” ‘55 F250 wheel that will work?
Otherwise I need to grind the caliper and put in a wheel spacer which I prefer not to do.
Thanks!
Thanks!
The following users liked this post:
Muppy, yes please share information about which clips you used. I tried using VW ones,and some 60's GM or Corvair ones and neither would work on my test wheel.
Really excited to know there might be a way to get them pretty wheel caps on my truck! The caps are sitting on a shelf waiting for me to figure out a way to attach them.
Tom
Tom
I’m gonna speculate that a set of the 17.5” x 5.25” Budd 73240s or 70720s would clear your calipers. Optional on F-250s from 1956 to 1966. Accept stock hub caps. While I’ve never tried them with disc brake conversions, I know first hand that they clear the big 14” rear Lockheed drums on early F-3s. Your ‘55 has 12” rear drums. They would use 8-17.5” tires that are about the same diameter as 7.50-16”ers. Stu
filthy6
06-21-2014 11:33 PM
dsrtjeeper
01-09-2013 11:01 PM
48' fordster
02-10-2009 05:57 PM
