Small engine fire, could use some help with wires
Old Nov 13, 2021 | 11:53 AM
TheBorgCollective's Avatar
TheBorgCollective
So, had a fire on the top of the engine after replacing the filter. Turns out the rubber line on the end closest to the pump cracked. So as Im attempting to start it, the carb backfires and catches the pooling fuel on fire. Luckily I had an extinguisher nearby.
Trying to upload a photo, but Ill need to resize it.
Ill need to replace the fuel lines, lightning cables, and the new temp sensor I just put in..
There were a few cables that will need to be replaced, but Ive never really done much electrical work. Looks like the ones leading to the capacitor (?) And maybe a few others. Ill get pics up when I can.
Also, best way to clean off extinguisher junk?
Old Nov 13, 2021 | 03:35 PM
Peter Gozintite's Avatar
Peter Gozintite
I had something similar happen years ago. Had to fix some minor damage. I dont remember cleaning the fire extinguisher debris being a big problem.
I would recommended investing in some heat shrink tubing for your wire splices. Dont just use the ****ty crimp connectors.
I have a Chilton manual that has helped me out immensely with wiring over the years.
Old Nov 13, 2021 | 08:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If it was a dry chemical fire extinguisher, use some compressed air.
Wire diagrams: https://www.ford-trucks.com/forums/1...l#post14696846
Old Nov 13, 2021 | 11:23 PM
arnegrant's Avatar
arnegrant
Fires aren't great, but basically follow the wires back to where they are good and splice out the bad part with new.
It's nice to try and keep the same color of wire.
I like to twist, solder, and heat shrink.
Good luck
Old Nov 16, 2021 | 01:40 PM
TheBorgCollective
Those diagrams are insanely helpful. I found that the whole section of wires running from the distro and coil to the ignition module is toast, but the plugs look okay and the groups of wires after each plug are fine as far as I can tell. I'm not sure if you'd call this a "harness", but is there anyone that sells this? Or should I just try recreating my own by splicing into what's left?
Old Nov 16, 2021 | 02:30 PM
TheBorgCollective
Alright I think I found what will work. But it mentions that it needs to be a "blue module" for the duraspark ignition? - https://www.painlessperformance.com/wc/30812
Old Nov 18, 2021 | 08:05 AM
CelticOne's Avatar
CelticOne
Regular User
This refers to the grommet colour on the ignition module.
From an old thread:
Ignition modules, 74 (black grommet) and 75 (green grommet) are year specific and will not interchange. 76 to 79 (blue grommet) are interchangeable.
Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's.
D4AZ-12A199-C 1974 only
Old Nov 18, 2021 | 05:05 PM
TheBorgCollective
Appreciate it Celtic!
Old Dec 14, 2021 | 05:54 PM
TheBorgCollective
Finally got down to replacing these wires... old man winter really did me in. But now that the weather is finally above freezing I can get things done. Decided to splice most of the new wires to the old harness. Frustrating that the new one wasn't an exact fit, but hey what are you going to do?
I do have a question on one of the wires however. The old square 4 prong connector leading into the cab.. there's a red wire with a white stripe. Does anyone know what this goes to? It's got a plastic piece on the end of it, but I can't make out what it was.
Thanks all
Last edited by TheBorgCollective; May 13, 2022 at 07:08 PM. Reason: Reworded and updated for clarity
Old May 13, 2022 | 07:24 PM
TheBorgCollective
And I guess this is just a newbie question, but what sort of aftermarket tach/oilpressure/etc gauges do you all recommend? My cheapo one was ruined, so I'm looking for something new to put in. If I can keep the old stuff working on the instrument cluster, that'd be ideal!
Thanks again!
Old May 13, 2022 | 08:50 PM
77&79F250's Avatar
77&79F250
All depends on how much $ you want to spend. Look at some AutoMeter, Equus, Jegs, Summit racing, Bosch ect...for a 3 gauge (oil pressure, temp and volts). Alot of big box auto parts stores carry a standard 3 gauge that has a bracket to hang then under the dash. Then you have to take your eyes off the road to at them way down there.
T it in the oil pressure sender if you have actual gauge versus warning lights.
Look for another place to put the temp sensor on the block, intake or t stat neck.
Tach is stand alone item usually and you can get a signal from the coil.
Old May 17, 2022 | 12:03 PM
TheBorgCollective
Thanks for that! I've got actual gauges on the dash instead of just the warning lights. Good to have a good idea of where that oil sending unit is. I've heard it's a pain to get at on the 460.
Anyone have ideas on that red wire with white stripe? Coming from the square 4 pin connector going into the firewall on the Drivers side. I don't believe it's the temp sending wire, but I could be wrong.
Old May 17, 2022 | 06:06 PM
TheBorgCollective
This is the connector I'm talking about
Old May 26, 2022 | 05:01 PM
TheBorgCollective
Finally completed carb rebuild and it runs! Thanks for the assistance everyone.
Still not entirely sure where that red/white striped cable goes... Been going through the important links sticky and even with the diagrams I'm not entirely sure. The illustration that shows the connectors doesn't seem to have one as above.
Also bought some $40 gauges for the time being so I know what temp I'm at
pfjellman
22
Sep 15, 2011 03:56 AM
joneringo
May 13, 2003 01:02 AM
pramos
22
Mar 28, 2003 10:04 AM
wkdenning
1978 - 1996 Big Bronco
Mar 2, 2003 11:10 PM
rcruzer
Sep 10, 2002 09:52 PM
