Wiring help
Old Nov 11, 2021 | 04:50 PM
1956in1956's Avatar
1956in1956
Wiring help
Hi
The 12 circuit board
hoping someone can help with some wiring advice.
im wiring my 56, using a 12 circuit fuse panel and having problems getting the tail light / brake light/ signal light work properly.
Using new ford tail lights with 1157 bulbs, the problem is - with right or left signal flashing when I apply brake light- they stop flashing, I have tried a 2-3 tail light adapter from CURT but no difference.
I'm using a ford steering column from a 68 LTD,
I have swapped and tried every wire Combination I can think of.
I have the flasher to the steering column signal selector, out to left and right, then add the brake wire and lights stop flashing.
seems like there’s something I’m overlooking???
relays??? Or diode’s???
any help would be Greatly appreciated
Old Nov 11, 2021 | 07:18 PM
Old F1's Avatar
Old F1
I am not sure i completely understood what you said but I wont let that get in my way.
With the '68 column (and most others) the brake light switched circuit comes into the turn signal switch and then out to the brake lights.
Old Nov 11, 2021 | 07:26 PM
1956in1956's Avatar
1956in1956
Thanks
Ill try that tomorrow , I was taking brake wire directly to tail light wires.
ken
Old Nov 11, 2021 | 07:51 PM
burnettd01's Avatar
burnettd01
I am using a 63 Ford Galaxy steering column in my 51 F1 and Oldf1 is right - the brake light power goes in to the turn signal switch which feeds to the brake lamps. The turn signals are powered separately and feed from the flasher unit to the turn signal switch. The turn signal switch operates both turn signals and brake lamps.
So, basically, the turn signal switch tells the lights what to do. Make sure that the turn signal switch is working properly. If you have a connector between the t/signal switch and the wire harness, disconnect it and use jumper wires to power up the brake light feed and t/signal power wires at the switch and see if the t/signals work properly then apply the brakes to verify that the t/signals work properly with the brake lights on.
If they work properly, then your problem is between the switch and the lights in the rear. First check your grounds to make sure there is no feedback. Your lights in the rear will need one wire from the turnsignal switch for each side to operate the turn signals and brake lights. You will need a ground wire for each rear light and a tail light wire from the headlight switch.
I suspect a bad ground or maybe it could be a bad turn signal switch..
Let us know what you find..
Good luck
Dan
Old Nov 11, 2021 | 07:53 PM
Old F1's Avatar
Old F1
See if you can Google a wiring diagram, most years are kind of the same.
Old Nov 11, 2021 | 08:04 PM
1956in1956's Avatar
1956in1956
Great , thanks Dan
I’m going to try that, and will post an update on the results .
ken
Old Nov 12, 2021 | 02:46 PM
1956in1956's Avatar
1956in1956
Got signal brake lights working
Thanks guys for the help, got Brake, signal working, write this down in the book 🥳
ing
Old Nov 12, 2021 | 04:50 PM
burnettd01's Avatar
burnettd01
What did you find that was causing the problem?
Old Nov 12, 2021 | 05:09 PM
1956in1956's Avatar
1956in1956
I was using a multi meter to track the line Continuity, It never occurred to the brake light would feed into the steering column, followed these instructions and bingo lights work, signals work, tail lights work, 4 way flasher work.
my steering column is from. 68 Ford LTD.
thanks for the help guys.
APeacer
2004 - 2008 F150
Jul 17, 2020 09:00 AM
rickse350
Electrical Systems/Wiring
May 6, 2015 11:11 AM
Rose Clifford
Dec 30, 2011 11:41 PM
mwood65
Oct 21, 2006 12:42 PM
19gator55
Nov 25, 2004 07:03 PM
