92 E350 LEPRECHAUN MOTORHOME LIGHT ISSUES
Go up to the bottom of the steering column. See if you can find a lightgreen/orange wire. If you find it, poke it with a testlight and see if the testlight lights up when you press the brake. The right side that works is a orange/lightblue. It's working and the testlight should light.
If the left side works at the bottom of the steering column, then you have a wiring problem from the front to the rear. If it doesn't work I suspect a problem in the turnsignal switch. Here's a diagram, look in the lower right corner diagram.
Steve
deich
06-19-2017 09:34 AM
Michael McQueen
02-26-2012 12:14 PM
robmatt
05-25-2003 04:27 PM
